Old 06-16-2011, 09:21 PM
67gtocharlie 67gtocharlie is offline
Default A/C diaphragm switch replacement
I broke my A/C diaphragm switch that is on the heater/AC unit on the firewall. This part has to be bolted on from the inside of the box and hooked up to a lever. My question is, what is the easiest way to replace this switch? Do I have to tear down all of the A/C and remove the whole box? I guess this "box" as I call it is really called the evaporator (?).
Any help would be appreciated greatly.
Also, just what exactly does this switch do?
Thank you so much.
67 GTO Charlie
Old 06-19-2011, 11:45 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
It's not a switch at all. It's an actuator that moves the air recirculation door when you call for max A/C ("Inside" on the A/C control). They are available repro. Also, if you're game to look for one in the boneyard, that same actuator was used on B and C bodies in the 70's. On those cars, it's located on the interior A/C housing, next to the gas pedal. Because it's inside and not exposed to heat, they last forever in that location.
To change yours, unbolt the blower housing from the firewall and then unbolt the actuator. The evaporator is in the RH cowl on your car, so you don't have to disturb any of the refrigeration components. You MAY need to pull off the heater hoses to get the blower housing off.
Old 06-20-2011, 04:01 PM
Andre's Avatar
Andre Andre is offline
Also located on all A bodies with a/c 68-72 behind the passenger side kick panel.
You must unbolt the blower housing from the firewall to change out. One or two bolts are tough, but can be done with the fender still on the car.
Old 06-20-2011, 10:26 PM
hgerhardt's Avatar
Originally Posted by Andre View Post
Also located on all A bodies with a/c 68-72 behind the passenger side kick panel...
Is that one the same as the '66-'67 with two vacuum nipples?
Old 06-22-2011, 12:39 PM
Default Thank you for the info
I forgot to say the car is a 67 GTO. Yes, the actuator has two vacuum nipples on it. I appreciate the info on replacing the part. I thought that I had to remove the blower housing; I just hope I can do that without tearing down the A/C stuff.
Thanks again!
67 GTO Charlie
Old 06-22-2011, 01:09 PM
Old Goat 67's Avatar
Yes, you can do that.
Old 06-24-2011, 01:17 AM
hgerhardt's Avatar
... I thought that I had to remove the blower housing; I just hope I can do that without tearing down the A/C stuff.
Thanks again!
67 GTO Charlie
Charlie, you gotta read our entire answers. As I said in my first reply to you:
Originally Posted by hgerhardt View Post
...To change yours, unbolt the blower housing from the firewall and then unbolt the actuator. The evaporator is in the RH cowl on your car, so you don't have to disturb any of the refrigeration components. You MAY need to pull off the heater hoses to get the blower housing off.
