Old 08-24-2011, 11:10 PM
GoatandBirdCollector GoatandBirdCollector is offline
Default WQ 400 Block For T/A
I'm looking for a 9792506 WQ 400 block for my 69 T/A
Any leads would be appreciated.
My car currently has a YU 350 block which just won't do....
Runs fine, but I'm told too many 1/4 mile runs deceased the original 400 long ago.....
Any help appreciated.
Old 08-24-2011, 11:18 PM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
You are likely looking for a WQ with a casting number of 9790071. The 2506 would be a RAIV block.
Old 08-25-2011, 06:14 AM
alex s's Avatar
alex s alex s is offline
Give me a call 508-808-1290 I have a WQ Engine Avail. Alex
Old 08-26-2011, 08:48 PM
Is this a complete motor or just the block?
Are the main caps still on the block?
Thanks!
Old 08-26-2011, 08:50 PM
I think that's a 68 HO engine.
Thanks!
Old 08-26-2011, 09:59 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Thanks!
I think you need to check your sources as Uncle Judge is correct in his statement.
Old 08-27-2011, 07:03 AM
alex s's Avatar
All 69 RA III blocks are 071 castings as stated except for late production as they were 914 blocks after late june . Never a 506 unless a RA IV .
Old 08-28-2011, 11:18 AM
OK, Thanks.
Good to know.
My source was a list posted by pontiacpower.net.
They only listed 3 WQ blocks & the 506 was the only 69 R/A III on there.
Thanks for setting me straight.
Old 12-26-2024, 01:06 PM
Rcpeake Rcpeake is offline
Default 69 400 Engine
looking for a WQ 400-69 manual engine for my trans am? any help would be appreciated! thanks
Old 12-26-2024, 03:36 PM
Ramairnacho Ramairnacho is offline
I got correct distributor only 1111952 all original
The Following User Says Thank You to Ramairnacho For This Useful Post:
Old 12-27-2024, 03:33 PM
turbo69bird's Avatar
Yes this information IS correct
I had a WQ and it had a 952 distributor in it all original. Difference was HO and RAIII had the long branch the regular WZ did not. Had to edit that had the WZ lumped in w the WQ. Forget those had differnt codes sometimes.
As far as I know 2506 is RAIV only.
960 HP @ 11 psi, 9.70 at 146.
Old 12-27-2024, 11:43 PM
rwfisher's Avatar
rwfisher rwfisher is offline
I may be interested if OP isn’t…..
The Following User Says Thank You to rwfisher For This Useful Post:
