Old 09-29-2011, 04:31 PM
OldS-man OldS-man is offline
Default 62-4cyl frnt seal and lifter ???
I pulled the engine on the 62 Tempest I'm working on.
the front seal looks to be not a normal front cover type. I saw in another post
that these can be replaced with a flange type. what would be the correct size to machine the cover to accept the new style seal. And are the lifters the same as
the V-8 lifters.
oh and what pistons can I use when / if I bore it
thanks.
Old 09-29-2011, 06:24 PM
tom s tom s is online now
actually the seal is the normall seal for the pre 63 engines.Just get a seal from any other years like 67 or so and have a machine shop put it in.Lifters are the stock hyd lifters and you want 389 plus what ever over bore you get to.Tom
Old 09-29-2011, 08:40 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Details about replacing the front seal with a lip seal can be found here.
http://www.pontiacsafari.com/L1Garag...ealUpgrade.pdf
I'll loan you my alignment tool for a $50 deposit, cheerfully refunded upon return. You pay postage both ways. It's been used on nine Pontiac engines now all over the country.
