Old 10-18-2011, 08:04 PM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default looking for good heads
I want to purchase some heads to fit a 400 block? not sure what #'s i should be looking for? I was told to find something in the 1960's with 70cc... any ideas would help.
Old 10-18-2011, 08:41 PM
wovenweb's Avatar
wovenweb wovenweb is offline
If you are looking for correct code heads for a '69 400 engine, I'm fairly certain you are looking for #16 heads which would be 72 cc's. I'm not sure which casting dates would be correct however.
I do have a set of #16 heads for sale with a casting date of C218 which would make them correct for a late 1968 car. Always an option if you are interested.
Old 10-18-2011, 11:21 PM
There are a lot of options in the 70cc range.
Big valve with screw-in studs are most popular.
670 / 16 / 62 / 48 / 12 / 13
You'll be around 10.5 - 11.0 CR depending on bore size - milled depth - piston to deck clearance etc...
Are you wanting correct 1969 heads ?
Here is a website with good head info :
http://www.wallaceracing.com
Old 10-19-2011, 08:09 AM
69 redbird's Avatar
Thanks, checking out website now. I saw someone on here with #92 heads for sale. Looks like there 70cc also...
Old 10-19-2011, 08:46 AM
69 redbird's Avatar
not really, just want more compression/power... i have #46 right now in a 350 and have no power what so ever...
Old 10-19-2011, 09:22 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
If you can find a good set of 670s grab them. They are great stock heads.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 10-19-2011, 11:30 AM
Ron Landis's Avatar
Wink Those...
are VERY different form a '69 casting 16#...as the only 16# used in '69 model year was a pressed-in stud, low compression small-valve head that came on some two-barrel cars. A '68 16# is the large-valve, high compression screw-in stud heads. There was some confusion early on when erroneous material was printed. A '69 400 in a GTO, Firebird or GP would have had either 48# or 62# castings...depending on application. Two barrel cars are the exception. Check Eric White's book...it is accurate as far as I know. Others...not so much. Ron
Old 10-19-2011, 02:13 PM
If your #46's on the 350 - are 1973 or 1974 models - those are really some pretty decent heads and have screw-in studs. In previous flowbench tests - they performed as well as many of the 1960's performance heads.
I forget what the chamber cc is on them.
They also have hardened seats for unleaded fuel - 1972 and older mostly will not.
But have read claims of some 71-72 heads having hardened seats. idunno
1973 and newer will have them though.
If you run under 8.5 : 1 CompRatio with hardened seats - you can use 87 octane unleaded.
Believe 9.5 : 1 CR with hardened seats - is about max for 92-93 octane unleaded.
If you get into higher CompRatio's than that - you'll need race gas/aviation gas blend(s) and lead additives and things like that. It gets expensive in a street car.
The best, highest quanity, and cheapest HorsePower comes from Cubic Inches and Camshaft selection. Higher Compression Ratio is not a big factor in street engines until way way further down the line when you're trying to milk every ounce.
Another head to consider on a 400cid is the #64 from 1970 455 HO.
80'something cc's IIRC.
The higher the CompRatio - the more you have to spend on fuel.
Heads without hardened exhaust seats - an added expense to have them installed - or added expense at every refuel for lead additive.
Things to consider.
Old 10-19-2011, 02:17 PM
Not familiar with #92 heads at all.
Maybe they are 1969 #62 heads ? Those are usually around 75cc
Old 10-19-2011, 07:13 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
Probably 092 heads. 1966 389-421 4bbl. head.
Old 10-19-2011, 07:54 PM
wovenweb's Avatar
Thanks for the clarification Ron. The NOS fenders I picked up from you/your son look great!
Old 10-22-2011, 10:48 AM
69 redbird's Avatar
Default Great info
Gives me a lot to think about
Old 10-23-2011, 12:50 AM
68toplessgoat 68toplessgoat is offline
I have a set of 670 heads if you are still looking. let me know [email protected]
Thad
Old 10-23-2011, 07:24 AM
jetallman's Avatar
jetallman jetallman is offline
I have sets of #16,#62,#13 #061
69 455/4-sp windward blue under major restoration
69 400/400 waiting for resto
Old 10-23-2011, 12:43 PM
how much for the 62?
Thad
