Old 11-30-2011, 12:40 AM
RomWar2 RomWar2 is offline
Default Rally II wheel interchange for JY code
Any idea whether or not other 5x5 Rally II wheels will fit a 1971 Grandville with front disc brakes? Been looking all over for the original JY code Rallys with no luck. Really just want a good fit, not originals.
Old 12-01-2011, 04:48 PM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
I have used various different codes on my 70 Bonneville with disk brakes, with no issues. I'm not positive, but I think all the 5X5 15" Rally II's have the same back spacing and will fit. There are a few, hard to find 5X5 15" that are 7" wide instead of the much more common 6" wide. I think they were mostly on station wagon or trailer towing packages.
Old 12-01-2011, 05:34 PM
Default Thanks
That explains a lot. I know they had ambulance and hearse applications that year as well.
Old 12-01-2011, 10:18 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Another thing to keep in mind is that not all of the 5x5, 15x6" wheels were created the same. Some had a smaller diameter center (if memory serves, they're JU code from 69-70 big cars) and they don't look the same externally when side by side with other 5x5 wheels.
This summer, I sourced 4 5x5, 15x6" Rally II's for my 74 Bonne, and I ended up with two KY and two HY code wheels. They match up nicely on all measurements, and they're listed for 73-76 big cars. No clearance issues with the big discs on my car either.
Lastly, the 5x5, 15x7" Rally II's were supposedly on 77-81 big cars, and carry the HH or KD code from what info I have.
Hope this helps. Good luck finding a set! They really make the look of the B-bodies IMO.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 12-02-2011, 11:43 PM
I think the 69-70 used the large centers. Using a smaller center from a 14 inch wheel would mean 4 3/4 bolt circle, which would fit A and F body cars.
Old 12-03-2011, 11:17 AM
dedsleds's Avatar
dedsleds dedsleds is offline
71-76 rally 2's off of a fullsize pontiac (5x5) will work on the 71. 71-2's full size rallies look a little different, more like a 1969 70 raLLy. but they will all work. drum brake fullsixe rally 2's off of 67-70 will not work for you, but 71-76 would work on 67-70 drum brake cars...
1959 catalina 4dr a/c car
1970 gp strip car ...
1972 gp j 455/4
1971 bonneville hearse 455/4
1972 grand safari wagon 6 pass 455/4
1995 Firebird Formula 5.7 convertible
2002 gp 40th anniv. SC V6
2003 gmc sierra 2500hd 8.1 liter
***LIKE MY FACEBOOK PAGE https://www.facebook.com/GratefulParts***
http://stores.shop.ebay.com/GRATEFUL...__W0QQ_armrsZ1
Old 12-03-2011, 08:28 PM
I haven't looked it up, but I think 70 switched to JY mid year. I have a bunch of different 5X5 15" and they all appear the same to me, except for 2 that don't have the 3 cut outs where the center cap goes. I don't recall the code, but I think they are later model wheels. There is also a slight ridge under the trim ring, and the ring fits slightly differently. If I didn't point it out, most people would never see any difference, because it is slight. I used them on the rear, because the only way to attach the center cap was with the plate and center screw, which would hit the bearing cap in the front.
Old 12-03-2011, 11:27 PM
According to the 1970 Pontiac Parts Manual I have, the 1969/1970 B body Rally Wheel is code JJ. My broadcast sheet, list the Rally II's for my 70 Bonneville as JU, so I guess that was the mid-year change. The 1968 B body Rally II wheel was 14 X6 and was code JB, and I think they were still 5X5, but in 14".
Old 12-05-2011, 04:23 PM
Here is a link for various Pontiac wheels. It is not complete, and there are a few corrections needed, but it is still a good guide
http://www.pontiacserver.com/wheels.html
