Old 12-05-2011, 04:08 PM
68GTO-Joe's Avatar
68GTO-Joe 68GTO-Joe is offline
Default 1968 GTO Instrument Cluster Removal Advice Needed
I want to remove my instrument cluster. I know that i must remove the 3 top screws, speedo cable and radio dial nuts. There seems to be fasteners at the bottom of the cluster to remove. The service manual is not helpful. Can anyone provide info as to how to loosen the bottom of the cluster?
Joe
Old 12-05-2011, 04:27 PM
petesake's Avatar
petesake petesake is offline
Joe:
There are 2 speed nuts behind the dash cluster that attach to 2 studs. The go through the metal dash part and are found on the lower part of the instrument cluster. If you do a search I think someone has posted pictures.
Old 12-05-2011, 04:53 PM
68GTO-Joe's Avatar
Thank you.
Old 12-13-2011, 08:07 PM
fred421 fred421 is offline
Picture of the speed nuts behind the dash cluster that attach to 2 studs. Do your self a favor and drop the steering column .
ID:	266967   Click image for larger version
ID:	266968   Click image for larger version
Old 12-13-2011, 11:23 PM
68GTO-Joe's Avatar
Thank you for the pictures and the advice. They are a great help.
Joe
Old 12-14-2011, 09:44 AM
gto66yellow gto66yellow is offline
Joe I have also had them with a stud over to the right side of the radio. heater control is a real pain i unhook it from the bezel before I remove it
Old 12-14-2011, 12:30 PM
68GTO-Joe's Avatar
Thanks for the additional info. I think mine has not nut by the radio as it is loose. I also need to remove and fix the heataer control.
Old 12-14-2011, 10:13 PM
GTO68FXSTC98's Avatar
GTO68FXSTC98 GTO68FXSTC98 is offline
I left my heater control in place and undid the three cables. You have to be careful not to scratch up the paint when you pull it. Dropping the steering column def. helps.
I took apart the fan switch (by bending back the tabs) and cleaned it all up inside and got it to work again. Tested it with an ohm meter for resistance to check it.
Old 09-28-2024, 04:48 PM
RustRevivalGarage RustRevivalGarage is offline
Wanted to say thanks for all the advice in this forum! I used this to make a YouTube video! And for anyone who finds this forum looking for a video…. it exists now.
Here’s the link: Removing a 68 Pontiac GTO, LeMans or Tempest Instrument Panel
https://youtu.be/XvzCZz286O0
Hope it helps someone!
The Following 2 Users Say Thank You to RustRevivalGarage For This Useful Post:
Old 10-29-2025, 10:38 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Great video, it will help me with my 68 GTO now I can remove my clock and get it working unless someone had a better way
color me gone
Old 10-29-2025, 11:48 PM
OG68 OG68 is offline
It's tight but you can remove the clock without removing the dash.
Old 10-30-2025, 12:36 AM
1969GTO's Avatar
Any advice or suggestions to remove the original clock without removing the dash?
And what are the common problems with the clock not working?
color me gone
Old 10-30-2025, 11:51 AM
Most common problem is the electrical contacts become pitted and burn't over the years. The operating mechanism may need a drop or two of light machine oil.
68 and 69 clocks and tachs are easier to remove than replace. A 1/4" ratchet with a flexible wand extension works well. The hardest part is getting the screws started when installing.
Pontiac recognized this and opened up the mounting tabs on the 70-72 tachs/clocks allowing the screws to remain in place. Just loosen the screws, rotate the clock and remove
ID:	659694   Click image for larger version
