Old 01-03-2012, 10:19 AM
niceta's Avatar
niceta niceta is offline
Default Rear spring offset in F-body
Can someone explain why there is an offset in the rear springs, front bushing. The stock springbushings are both offset towards the passenger side. My new springs from Pro-touring F-body appear to be offset the other way towards the drivers side??. I have read a post on Trans am country where you can romove one of the bushings and install it so that itis in the opposite direction. The result is a slight toe in situation on the rear tires.Can anyone confirm this or tell me why this offset exists. Thanks.
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes.
https://www.facebook.com/media/set/?...7567172&type=3
The Following User Says Thank You to niceta For This Useful Post:
Old 01-03-2012, 09:17 PM
fsted fsted is offline
hi a solid rear axle should not have toe in or out, if you have toe the rear end is bent. the front spring eyes are mounted slightly closer together than the rear, this to help center the rear under the car. i am not familiar with the offset you are describing, maybe someone else will chime inn. hope that helps. Ed
Old 01-04-2012, 03:00 PM
Bigger is Better's Avatar
Bigger is Better Bigger is Better is offline
Hi there,
Its been a while but I know what you are talking about, outside of the bushings being inserted the same side are they not the same width/offset?
Dave's springs come from Landrum and they are stock car springs so are not concerned with a left/right difference other then spring rates maybe.
So if they are significantly offset you can see if you can center the bushings or you can move them.
In practice unless its a large difference it most likley not a big issue as the rear of the springs are rubber/shackle mounted and there is lots of compliance there to take up any sort of toe in/out issue.
Johnny
1980 455 TA
Autocross/Hillclimb
Powered by SD Performance
http://youtube.com/watch?v=Xc5rpSGwXlM
Suspension by www.pro-touringf-body.com
