Old 01-07-2012, 10:13 AM
BlackBird68's Avatar
BlackBird68 BlackBird68 is offline
Default any modern suspension upgrades for a '68 bird?
I am considering updating the suspension system while I have the car apart but am not sure what, if any modern suspension upgrades might exist.
Anything to make the ride a little bit softer and give the car better agility around corners.
right now I have mono leaf springs, front discs and rear drums.
Old 01-07-2012, 09:27 PM
FatfreeGTO FatfreeGTO is offline
There is a huge aftermarket for making the first gens handle better. The sky (and wallet) are the limit for what you can do.
Getting a softer ride and better agility don't always go hand in hand though...
For many people companies like Hotchkis make systems that more then fit their needs. Here is a link to their 67-69 firebird products http://www.hotchkis.net/search.html?...mitForm=Search
They would in all honestly be your best bet as a starting point. If you want to learn more check out some other car forums like
http://www.pro-touring.com/forum.php
or
http://www.lateral-g.net/forums/
William (BJ)
1966 Pontiac GTO
Old 01-08-2012, 10:15 AM
Chupa's Avatar
Chupa Chupa is offline
yes a ton of stuff.... look at pro-touring camaro stuff...
Old 01-21-2012, 10:35 AM
stobin's Avatar
stobin stobin is offline
I would also look into Global West. Speak to Paul, he can answer all your questions.
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme.
Old 01-21-2012, 11:51 AM
First Bird's Avatar
First Bird First Bird is offline
My advice would be to first look at David Pozzi's authoritative overview of First Gen suspensions, what's wrong with them, and how to make them better.
http://pozziracing.com/first_gen_suspension.htm
- Tom
Old 01-22-2012, 04:37 PM
Pontirag Pontirag is offline
factory rating springs and rubber bushings for a nice ride.
Front and rear antisway bar with poly bushings. Good shocks with poly bushings
A mild change in steering box ratio and effort
Good Eagle or BF Goodrich radials
