Old 02-16-2012, 11:01 PM
BlackBird68's Avatar
BlackBird68 BlackBird68 is offline
Default cylinder head date code
Hey there,
I am looking at a set of 6x heads online and the pictures don't show whether they are 6x-4 or 6x-8
There is a dated code though in the picture, it says "e286", can this help me figure out which it is?
Old 02-16-2012, 11:06 PM
jdh421's Avatar
jdh421 jdh421 is offline
The date code E286 would be for May 28th 1976. The -4 or -8 will be stamped on one of the vertical castings next to where the valve cover bolts on. you will see a 1/2 inch square pad machined on the casting. the 4 or 8 will be there.
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 02-16-2012, 11:42 PM
WDCreech's Avatar
WDCreech WDCreech is offline
The Wallace site has a lot of info, including a picture of a head with code locations.
http://www.wallaceracing.com/headsearch.htm
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 02-17-2012, 07:43 AM
steve25 steve25 is online now
You can tell if you have the small chambered 6X heads just by sitting a head gasket on the deck.
With the head gasket in place the small chamber head will show way more than a 1/4" between the fire ring of the head gasket and where the lip of the chamber drops off.
This is viewed on the spark plug side of the chamber.
Old 02-18-2012, 11:12 AM
Ollie's Avatar
Ollie Ollie is offline
This shows the location of the secondary head stamping.
OOP'S wring photo, how ever the number stamped on the boss just to the left of the arrow
Its ok to giggle and snicker, Dont laugh and point
