Old 03-21-2012, 08:48 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Default Kick panels and new carpet.
Should you remove kick panels to properly install new carpet?
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 03-21-2012, 10:27 PM
GStage1's Avatar
GStage1 GStage1 is offline
Yes, so carpet can be cut properly along kick panel bottom
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 03-22-2012, 06:46 PM
goatless's Avatar
goatless goatless is offline
Absolutely!
1966 GTO
Old 03-22-2012, 11:35 PM
GOAT WHORE's Avatar
Thanks guy's that's what I thought. The driver panel is a biatch to get out!
So I had to modify my trans hump for my TKO 600 and I think I might have to cut the molded carpet to fit, I bought some yardage, can I tape the seams like house carpet or how is it done?
Old 03-23-2012, 07:25 PM
ERIC AULL ERIC AULL is offline
Test fit it first....sometimes they give you a little extra at each door sill. An interior guy I know sometimes cuts a "V" shape over the hump if necessary,then seems in a piece, which the console covers...I THINK he sews the seam, the other stuff should work I GUESS. Eric
Old 03-23-2012, 07:27 PM
GOAT WHORE's Avatar
No console in this car.
Old 03-23-2012, 07:45 PM
goatless's Avatar
Like Eric says, there are a few extra inches on each side that are normally trimmed off. If you're lucky the carpet will lay decently over your modified trans hump and those extra inches will still make it to the sills.
1966 GTO
