Old 04-25-2012, 11:30 PM
cutlas cutlas is offline
Default DTM Epoxy on the interior?
I am redoing my interior and the previous owner stripped it down to bare metal.
Should I use DTM Epoxy on it?
I am going with a black interior, what amount of gloss should the paint be?
Joe.
1967 Firebird project in the works
400, 670 heads, 2802 cam, Hooker comp, Crosswind intake, Quadrajet, 700r4, 3.42 Posi.
Old 04-26-2012, 08:28 AM
I would use epoxy primer as a base. Top of the dash needs to be flat prevent sun glare from blinding you. 60% on the rest is what I normally spray..
Mike
former." --Albert Einstein
- Winston Churchill
Old 04-26-2012, 10:27 AM
Thanks Mike.
Is there any particular type of paint I should use?
Old 04-26-2012, 11:01 AM
Unclesamscandy's Avatar
Unclesamscandy Unclesamscandy is offline
in the black package tray area on a coupe there is generally three peices of metal that get painted (black in your case) and they ALSO should be painted FLAT. They are the molding at the bottom of the rear window! eliminates glare, as Mike said about the dash board!
Old 04-26-2012, 12:45 PM
dataway's Avatar
dataway dataway is offline
Slightly off topic but ...when I do some interior repainting work I'd like to match the red oxide colored primer used on floors, doors, back seat area etc. Anyone know of a product that would be good for this?
Thanks,
JohnnyB
Old 04-26-2012, 06:02 PM
paint guy paint guy is offline
Epoxy has little U.V. resistance so any areas that see exposure to the sun should be topcoated with something over the epoxy, or chalking will result.
Old 04-26-2012, 07:21 PM
I will topcoat all exposed surfaces.
Thanks for the responses.
On a side note, How does Epoxy do over POR15.
If I scuff the surface will it adhere well?
