Old 05-03-2012, 08:06 AM
thejag thejag is offline
Default 62 tempest brakes
Hi I'm a new tempest owner I need to know if the rear brake shoes are the same as the front, and where can I get rear shocks that does not cost a arm and a leg ? thanks
Old 05-03-2012, 10:27 AM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
Front and rear are the same. Do a search on "shocks" in this forum there are a number of discussions and alternatives.
Old 05-03-2012, 12:36 PM
thanks autozone has a listing for the back but not the front, 15.99 in stock! I've been searching this forum for the rear shocks but no one has a clear answer, I don't want to give AdvanceAuto 120 dollars apiece for them, but I'll keep looking, thanks again
Old 05-03-2012, 12:41 PM
GaryK's Avatar
GaryK GaryK is offline
I do not think they will fit. Chances of finding brake shoes at your local autoparts stores are slim. Try Ames or eBay if Autozone's do not fit.
Old 05-03-2012, 12:47 PM
elefantrider's Avatar
elefantrider elefantrider is offline
You'll need to get the shoes relined with new material.
Old 05-03-2012, 06:55 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
I will look thru my stuff. I got them at a ok price. John
Old 05-03-2012, 07:24 PM
heater63's Avatar
heater63 heater63 is offline
I've got 63 brakes from East West Auto 1-918-832-7077 and usa auto supply www.usapartssupply.com for not a bad price. I think they are the same as 61 and 62 brakes aswell
"If you aren't first, your last." Ricky Bobby 2006
Old 05-04-2012, 08:43 AM
Found it! Got mine from California Pontiac Restoration, This was in 07. Set of shoes front and rear, core chg., and shipping. $52.43. 714 245 9800. Part number, C5462872R
61-63. John
Old 05-04-2012, 01:52 PM
thanks guys, the autozone brakes fit fine, but I'm still looking for rear shocks, thanks again!
Old 05-04-2012, 02:26 PM
GaryK's Avatar
Are the shoes from Autozone bonded or rivited?
Old 05-04-2012, 02:50 PM
Wow, that is a scoop! Can you post a pic or the part number? Did you try them on the front.
Old 05-04-2012, 03:13 PM
mechanickeith's Avatar
Interesting,,,Auto zone has never had brake shoes for our cars. They start at 64 & go up from there. We would like to know the Autozone part number. I just tried a search & not available from AZ.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-04-2012, 03:40 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
I too am surprised about the brake shoes. But for the rear shocks try part number 82047 from NAPA. I just looked at mine and they have the number 739047 stamped right in the metal. They might be listed as being from a late 50's or early 60's chevy or GMC truck shock. Hope this helps.
Old 05-04-2012, 06:50 PM
azkeebler's Avatar
azkeebler azkeebler is offline
Interesting. My search comes up with these for $16.99. Pic look like riveted though.
Part Number: 245
Alternate Part Number: FB24
2-1962 Lemans convertibles 4cyl, auto
1962 Tempest safari wagon (running project)
1972 455 Formula (tribute)
1962 Skylark convertible 215 4-barrel , auto
2009 G8 Sport red metallic, Onyx leather
Whatever else that make my way into the driveway
Old 05-04-2012, 11:37 PM
With that number 245, I click on "info" & it says Does not fit my car!!
Keith Collier
Tech advisor
POCI.org
Old 05-05-2012, 12:41 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
Part Number: 245
Alternate should be FB245.
Worth looking into, Keith. Take a used shoe to the store to compare? Could lead to other interchange parts...
Old 05-05-2012, 12:45 AM
Checked both numbers at my local store, none in stock. Will check the wearhouse tomorrow & see whats available.
Keith Collier
Tech advisor
POCI.org
Old 05-05-2012, 09:04 PM
they are riveted and the part # is 245
Old 05-05-2012, 11:09 PM
# 245 & FB 245 are NOT the shoes for our Tempest's. They are for a 64 & up A body car. I laid a 61-63 shoe next to the 245 shoe & the 245 shoe is 1/4 inch wider. Wont work on our 61-63 tempest's.
Keith Collier
Tech advisor
POCI.org
Old 05-05-2012, 11:19 PM
blueghoast's Avatar
I bought my shoes and wheel cylinders threw Northen auto parts of
Grand Rapids Michigan. Core exchange required.
GT.
