Old 05-06-2012, 10:44 PM
70temp455 70temp455 is offline
Send a message via ICQ to 70temp455
Default Engine swap ?
Will a 69 400 manual shift engine bolt up to a 72 TH350 without issues ?
Thanks in advance !
ACE
Old 05-06-2012, 10:45 PM
Yes, no problem.
Old 05-06-2012, 11:45 PM
That's what I wanted to hear !
Any confirmations ?
Old 05-07-2012, 12:19 AM
Yes it will bolt up with no problems, the engine doesn't know if it's a stick or not.
Old 05-07-2012, 01:30 AM
Loffen's Avatar
Loffen Loffen is offline
As long as it is a BOP Th350 that is, if it is from a chevy you will need a adapter ( I guess you know that, but anyways.. )
Old 05-07-2012, 10:29 AM
2002Z4CSS's Avatar
Make sure to remove the pilot bushing from the crank before putting the automatic behind the engine or the torque convertor will bottom out.
1971 Pontiac GT-37
Old 05-07-2012, 04:25 PM
Good point about the pilot bearing !
I just seen to remember (and it might have been a Chevy thing) that the locating dowel pins were in different places for stick vs. auto. I just wanted to confirm that "Yes, it is a direct bolt-in" before I buy the 400 from my friend.
Thanks Guys ! ! ! !
ACE
