Old 06-26-2012, 10:24 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Default 1978 GP 301 to 400 swap
Helping a friend do this swap. Against my better judgement. AS he has a great running 301...
Keeping TH350 in place using most of the usable 301 parts. AKA Timing cover. He has new intake and carb etc..
Anyway, what are the best exhaust manifolds to get. I told him that I refuse to install headers. If he wants them later he is on his own. Anyone have a decent set?
Also any other information you might have would be great.
Thanks,
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 06-26-2012, 10:49 PM
rick840 rick840 is offline
Mad Dog makes them is several configurations. Does good work.
Rick
Old 06-26-2012, 11:00 PM
Sirrotica's Avatar
Dave, unless someone's changed the transmission it's a metric 200 tranny, not substantial enough for the 301 let alone a 400. You'll need a better radiator more than likely. The cheapy 3 tube headers fit this swap. RA III manifolds or the logs will work. Dual exhaust is going to require a different or modifying the transmission crossmember. Gear ratio is probably less than optimum unless your going for gas mileage The rest is probably pretty straight forward.
The 400 is about 125-150 lbs. heavier so the front springs may need help if they're marginal already.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-26-2012, 11:02 PM
Dave, unless someone's changed the transmission it's a metric 200 tranny, not substantial enough for the 301 let alone a 400. You'll need a better radiator more than likely. The cheapy 3 tube headers fit this swap. The rest is probably pretty straight forward.
Yeah, the tranny is not my worry. He installed a B&M shifter for a TH350, so I have to assume a TH350.
Which chepy headers? Are they easy to install? You know how much I LOVE headers..
The Burb Files
Old 06-26-2012, 11:21 PM
Sirrotica's Avatar
These type headers: http://autopartsway.amazonwebstore.c...source=froogle
I think they're easy to install, easier than 4 tubes are. There are probably other brands of 3 tube headers, these are the ones I found right off.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-26-2012, 11:29 PM
goatwgn goatwgn is offline
The shifter can also be used on a TH200. To see if he has the 200 (3speed), look to see if it has the word METRIC stamped into the pan. The 200 and 350 have the same shape to the pan, but the 350 one is larger (and is mounted with 1/2 headed bolts) vs 13mm. A 350 will also have a vacuum modulator, the 200 does not. "Full length"Headers stink for a mild street application(IMO). 3 tube "Shorty headers" shouldn't be too troublesome to install. For manifolds, I would try and use log manifolds for an earlier "A" body car (ones where both exit out toward the back and not the middle). Eventually, the rear end may be a weak point. While he drives it, I would be on the search for a 8.5 unit from a Buick GN or "T" type. Most '78-'87 "A", "A" Special, and "G" cars have a 7.5.
Old 06-27-2012, 12:15 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i would not use the 301 timing cover. i'm pretty sure if it even fits, it will only fit without a balancer. some low horsepower motors (77-78) had a hub instead of a balancer. way to tell, is those had bolt on timing marks where the good ones have cast on numbers.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 06-27-2012, 09:51 AM
Anyone have any radiator suggestions?
The Burb Files
Old 06-27-2012, 11:04 AM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
A factory replacement "heavy duty" cooling radiator should do fine. It kept a high compression 400 happy in my car when I was street driving it. The 3 tubes "may" fit. The tube that kicks around the starter on the drivers side might touch the firewall. The mad dog headers do fit well. I also think the R.A.R.E long branch manifolds would probably fit as well.
Old 06-27-2012, 01:33 PM
shotgun shotgun is offline
PY Staff -Tech
read this: http://gbodyforum.com/viewtopic.php?...header#p142332
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 06-27-2012, 04:41 PM
OOOOHHHHH...... Looks like I will get log manifolds. The header thing he can worry about later...
For the street I am sure the logs will be more than enough..
THANKS!!!!
The Burb Files
Old 06-27-2012, 11:02 PM
A.W.Dille A.W.Dille is offline
I'm running logs on my 85 and easy to set the exhaust up. As far as a radiator I got one out a mid eighties Cutlass that had a 307 Olds with A/C. Three core will work to keep it cool.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 06-28-2012, 07:11 AM
Which logs? A-body?
The Burb Files
Old 06-28-2012, 07:22 AM
zeebo's Avatar
zeebo zeebo is offline
yeah, for ease of fitment and street use, log manifolds are fine, and so are HO manifolds. IMHO...and yes, use like a modine heavy duty radiator for an AC car--3 row with the AC 7 blade fan and a hayden 2747 clutch.
oh, and make sure its a th350 trans, or you will be replacing that 200 metric with one in a short period of time...
Old 06-28-2012, 07:54 AM
I asked him yesterday and he assured me that it was a TH350..
Thanks!!
The Burb Files
Old 06-28-2012, 09:13 AM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
All log manifolds are not created equally.
There were some produced with a significantly larger collector area, but dadgum If I know which ones. I've seen them here, and while they are well off an HO or 4-tubes, it's a good option for a street driven cruiser. You can always go back and change them out when you get a chance.
Old 06-28-2012, 10:16 AM
zeebo's Avatar
good point..and i agree..some log manifolds have a larger outlet than others, and i cant remember which ones do offhand either..but that is correct...good ones to use tho are the early 70s ones with the cast in donut and no heat valve.
Old 06-28-2012, 11:11 PM
Which logs? A-body?
Mine are from a 400 out of a 73 Grand Prix.
Old 06-28-2012, 11:14 PM
Which logs? A-body?
Mine are off of a 400 out of a 73 Grand Prix. A body manifolds will work fine.
Old 06-30-2012, 10:24 PM
Don57 Don57 is offline
I replaced the 301 in my 78' Grand Am with a 76' 400 from a Trans Am. I used the log manifolds from a 77-78 Trans Am despite the 301 manifolds looking like they will fit. Because the 400 is wider, the 301 manifolds keeps the front pipe too close to the brake line, so you need the 400 manifolds. I used the motor mount brackets from the 301 Grand Am engine as they are different than the F-body brackets. My car already had a TH350 but I changed the 7.5 gears from 2:14 to 3:08. I used my 301 radiator and it works just fine....but then again we don't get the heat like you guys get. The 400 I got is from a 4-speed TA so it already had the larger harmonic balancer. I have since replaced the air breather to a drop base 2" type. My car has pictures of the restoration under that Gbody site (I don't know how to post the link) if you want to have a look. BTW, you will love the feel of the 400!
