I have two issues:The cruise control stopped working and the horns quit. Fuses are good in both cases
As far as the cruise control. Look for a vacuum leak near the controller. I had a rotted line. once I replaced it my cruise started to work again.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
For the CC X2 on the vacuum leak near the controller, our 99 GTP had the same issu, same fix. I ended up replacing all the plastic vacuum lines that run around the Super Charger also, at around 110,000 miles. The plastic had gotten brittle, and one of my wifes quick customizing jobs (she totaled the car 3 times!!!!!) caused them to start breaking.
On the horn, start with the easy stuff, is power getting to the horn itself? If so probably a bad ground or possibly horn. If not check the wiring but it is probably a horn relay or Contacts in the steering wheel. Good luck
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
My wife the drag racing champion has 2 speeds, full on the Gas and full on the brakes!!!!!!
She also gets easily distracted by shiny objects!!!!! And being down if Florida you probably dont remember ice on roads, only in Mojito's LOL!!!!! The last time she hit an icy spot on a clear sunny cold morning and went off the road, side swiped a fence, brushed up some pine trees, nicked a mail box, then bent the engine cradle on the curb she hit. We didnt keep the car long after I put it back together that time, traded the 99 GTX in on the 09 G8GT, so far she in nicer to the Aussie Built Car. She also ran into a parked car to miss a child (I don't blame her for that 1) and ran into the back of a Ann Arbor City Bus!!!! No explanation on how she managed that one though!!!!!
Have you ever thought of putting BIG bumper guards on her cars ??? lol
Funny you should say that, for some reason she does want a mid to late 70's 4-door LTD that she wants to paint black and put push bumpers on, her idea not mine!!!!! LOL!
