Old 08-11-2012, 06:16 PM
stockapearing455's Avatar
stockapearing455 stockapearing455 is offline
Default Lunati bracket master 292 for mild 455
Hi I have a reasonably stock 455. I just picked up a st of 6x 4 heads to replace my big chamber 4x heads (unported). I typically run 14.2s with the stock 3.08 gears in my 68 lemans. Im running a stock cam as well. I have a lunati bracket master 2 cam on the shelf. Its 292/292, 230 @ .050, and 490 lift. Im just tring to pick up a little et, and gain a rougher idle. On the same token, I dont want to over cam it? If its too much cam, I might just bolt on the 6x heads with some roller rockers, and gain some compression. Any opinions greatly appreciated.
Btw i also have a performer, a performer rpm intakes, and 2200 stall converter.
1968 pontiac lemans 400. 13.16@102/8.5:1 /6x-4/lunati bm 2 cam/ 3500 stall/3.55 gears.
Old 08-11-2012, 06:38 PM
Half-Inch Stud's Avatar
230/230 @ .050 is low risk in you 455 goals. See 12.2 ET signature on 89 Octane. Stars, idles without fouling, sounds right, runs hard.
Old 08-11-2012, 06:55 PM
awesome! The 6 x heads i picked up came with screw in studs, guideplates, good valvesprings, roller rockers. I think with the stock pistons and 6x heads i will be around 9:1 cr. way better than 8 to 1. I have been researching the bracket master for a pontiac , but couldnt find too many opinions on it.
Old 08-11-2012, 10:51 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
I run the bracket master II in my basically stock 30 over 400. Runs 12.7s in a 4000 pound lemans street car with mild converter and 3.73 gear. I shift at 5200 with stock rods and pistons. It has a nice thump at idle to. I have used it in two separate 400s and am happy with it.
Old 08-11-2012, 10:59 PM
gold bird's Avatar
gold bird gold bird is offline
Thumbs up
I all so run it in my car , works well .
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19
http://www.youtube.com/watch?v=6PaHbLnszS0
http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109
http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60.
Old 08-12-2012, 12:52 AM
cool. Im happy to here this. I am planning on keeping the 3.08 gears.
Old 08-12-2012, 10:35 AM
mels80ga mels80ga is offline
I ran that cam in a 400 in a 3400lb car with 3.73 gear on pump gas and ran consistent 7.70's in the 1/8 with a best of 7.67. Has a nice sounding idle and performs pretty well.
Old 08-12-2012, 09:35 PM
what heads were u running?
Old 08-13-2012, 08:15 AM
I was running 62's with a clean up on the runners and gasket match to the Fel Pro 1233 intake gasket, Performer RPM intake and a 750 Holley double pump carb.
