Old 09-26-2012, 08:13 PM
69 RA3 69 RA3 is offline
Default 69 ra3 carb?
I am looking for some info on a carb for my 69 ra3 4spd gto. I have gotten conflicting info about what is original. Some folks have said all 69's have 8273 carbs and some have said late production cars have 9273 carbs. My car was built in the first week of May 69. Does anyone know for sure? It's going to be a pricey purchase so I want to get it right. Thanks, Bill
Old 09-26-2012, 08:50 PM
tom s tom s is offline
early cars had the 8,later the 9.Im sure someone will chime in of when the date break was.My 69 Judge has the 8.Tom
Old 09-26-2012, 09:47 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
7029273 is correct for May 1969.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 09-26-2012, 11:35 PM
Which plant was your car built at ?
If it can be found - your original Buildsheet will tell you which carb came on it.
Not speaking of the PHS Invoice, but the self contained Buildsheet.
I don't have access to it anymore, but had a Buildsheet for a Mid-May Ram3 Judge from Atlanta. It was a 9273
Old 09-27-2012, 05:34 PM
Thanks for the info and quick responses. My car was built at the Pontiac plant and sold in Canada. Are you talking about the build sheet that is sometimes under the seat or gas tank?
Old 09-27-2012, 05:42 PM
Thanks for the info and quick responses. My car was built at the Pontiac plant and sold in Canada. Are you talking about the build sheet that is sometimes under the seat or gas tank? Bill
Old 09-27-2012, 07:40 PM
Yes, he is.
Old 09-27-2012, 09:32 PM
Thanks again. I'll start digging this weekend.
Old 09-27-2012, 11:54 PM
I don't have a 69 Pontiac Plant GTO Buildsheet stored on this laptop.
But here is a 70 Pontiac Plant GTO sheet for reference.
Where the horizontal and vertical lines meet - of the red marker T - there is a box labeled CARB. The carb code is VB for this YS code engine.
8273 would be XX
9273 would be XB
Good luck and hope you find it intact
Let us know how it goes.
Be glad its not a 69 built in Baltimore, nobody we know has ever found the Buildsheet in one of them.
Name:	70 gto vert 1.jpg
