Old 11-10-2012, 09:04 PM
ironman ironman is offline
Default Valve spring coil bind
Been buying parts as I find them for a future build. I have a set of Comp 26995 beehive springs that I will install at 1.7 and a set of comp 1.65 roller rockers, I want to run a crower 60311 solid flat tappet cam. I know to check clearances on assembly and I will be doing this just want to make sure that this combination of parts will work and I wont have an issue with coil bind before I order the cam.
Old 02-25-2014, 01:15 PM
antique69lemans antique69lemans is offline
Well it has been long enough... any feedback on how well the behive springs work? I would like to use this spring but it seems a little low on pressure for me.
