Old 12-08-2012, 10:14 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
Default '65 Power Windows...
How hard is it to convert a '65 GTO from crank to power windows?
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 12-09-2012, 08:55 AM
dhutton dhutton is offline
I used the kit from NuRelics to install power windows in my 64 GTO. They worked well. The installation was not too complicated but plan on at least a day to do it.
I did find that if you replace all the seals at the same time that you need to lubricate them or the drag is too much on the glass.
Don
Old 01-08-2013, 09:03 PM
T.Weber's Avatar
T.Weber T.Weber is offline
I converted my manual windows to power windows in my 72 Cutlass. I installed all used factory stuff from a 71 Monte Carlo. I wanted it to look factory and it took me 3 days to do it all. To drill out the door jambs and doors for the wiring boots or conduits both front fenders (bumper etc.) had to be removed, the doors had to be removed, the front seats, console, back seat, and side panels & carpeting needed to be removed. The lower A/C ducts needed to be removed. I ran EVERY wire, fitting & clip in the factory locations. I'm anal retentive about keeping everything looking as if it was factory installed. I did all of this by myself without any help so that did slow me down a lot.
Old 01-09-2013, 08:32 AM
2002Z4CSS's Avatar
I have installed factory power windows on many of my cars and trucks in the past. Not a bad job. If you remove all of the necessary items, just mark them well and take photos of the harness routing.
1971 Pontiac GT-37
Old 01-09-2013, 08:46 PM
Goathead's Avatar
Where do the switches go, in the holes left by the window chrak shafts?
Old 01-09-2013, 08:57 PM
Old Goat 67's Avatar
That's what I did when I did mine.
Came out OK.
Old 01-10-2013, 08:52 AM
2002Z4CSS's Avatar
Most of the cars I installed power windows on that is where the factory also had the switches.
1971 Pontiac GT-37
Old 01-10-2013, 04:31 PM
Goathead's Avatar
Would this be a good way to go but with factory switches?
http://www.ebay.com/itm/1964-1973-PO...d6a2ed&vxp=mtr
Old 01-11-2013, 09:52 AM
Goathead's Avatar
Or is there a better way to go?
Old 01-13-2013, 08:15 PM
T.Weber's Avatar
Personally I would go with something like this. Definately more money but a lot less headaches in the long run.
http://www.ebay.com/itm/1964-1965-CH...ca7634&vxp=mtr
