400/ 455 "stroker" crank
Wanting to build another 455 for my 66 Tempest and already have a 30 over 400 block. Question is where is the best place to buy the 400/455 crank and will i need to buy anything "special" to put this combo together? Thanks
I would go with Butler or Super Duty Performance. They both have complete rotating assemblies.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
The Butler 461 stroker kit is a deal.
I agree! This is hard to beat!
http://www.butlerperformance.com/pro...s.html#462_468 455-468 cu. in. for 400-428-455 block New Crank 4.210" Stroke 3.00" or 3.250" Main for 400-428-455 Blocks Forged Pistons .030", .040" - .060" over (.030” & .060” over w/ROSS pistons) 6.625" forged rods Pin Fitted Seal-Power or Total Seal Rings FM/CL Rod and Main Bearings Balanced Internally Specify 3.00" or 3.250" Mains 455-468 cu. in. Rotating Assembly KEITH BLACK FORGED ICON PISTONS & I-Beam Forged Rods (press-fit) $1399.00 455-468 cu. in. Rotating Assembly KEITH BLACK FORGED ICON PISTONS & H-Beam Forged Rods (bushed) $1579.00 455-468 cu. in. Rotating Assembly ROSS Forged Pistons & H-Beam Forged Rods $1649.00 455-468 cu. in. Rotating Assembly ROSS Forged Pistons & H-Beam Rods & 4340 Forged Crank $2049 (3.00" main) $2099 (3.25" main) If this is a street car and not a RACE car this is hard to beat for $1,399.00 ! I would get the "Total Seal" rings along with having them assemble pistons and rods (if press fit is used) so the price would go up, but for a balanced assembly this is cheap. A balance job cost me $200.00. Just because this is a "Kit" doesn't mean it will be perfect; you should still check all measurements yourself during assembly. Karl |
Nice thing about the Butler kits is it's not just a bunch of parts tossed into a box. They go over it, and it's usually pretty spot-on. Sure they're may be exceptions, so checking is always advised.
I've bought two from Butler and am happy as hell with both sales. Sevice after the sale can't be beat. .02
I bought the Butler kit 5yrs. ago. Great deal,quality parts
Attachment 306026
color me gone |
I used a stock 455 crank and cut the mains down to the 400 3" and used Ken Keefer's shim and main bearing solution. About 1500 miles so far with no issues what so ever.
Make sure to clearance the block for the 455 crank throws. |
Whatever it is, make it a forged assy.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
Really, no matter what? A cast crank won't be good enough to spin up to say 5500 or even 6000 rpm? If I had the money I would get a forged crank as well but most cranks street driven are cast and do fine.
Take it as you will as this was just my experience. As HWYSTR455 stated, the best thing you can do is have everything checked out. With that said, I wouldn't waste my money buying already balanced etc. I think you would be better off buying the parts and having a reputable shop check all the dimensions and balance it for you. |
mines a cast crank, when I race and yes just test n tune days I shift my 400/462 @ 5500 and no problems.
color me gone |
From what I have heard, there are too many variables in the aftermarket cast arena. Ask Cliff what he has seen with respect to stress fractures on the new Chinese cast units. If it was a original nodular unit, then I would be all for it. For $400 more...a forged crank allows me to sleep a little better at night.
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC] http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
I have a cast crank 3.5 mains 5.21 bore X 4.25 stroke in a 455 block in my 65 LeMans bracket car. This the third cast crank I have had in this engine over the past 17 years. The engine started out as a street/strip low 12 second car. Over the years as I upgraded with different cams and heads it moved up to an 11 second street/strip machine and eventually moved into the 10's and got her a trailer and she retired from street duty. This car did bracket racing, street racing and thousands of hard street miles. This was with an OEM cast crank that was stroked. After several years of street strip bashing during the first freshen up I found some very small cracks in the rod journal radius and installed a new 455 OEM cast crank. After several more years of service during the next freshen up found small cracks again and installed an aftermarket cast crank from Ohio Crankshaft. I had this crank cryogenically treated and have had this crank in the motor for a few years now with just bracket racing and no problems. This engine was making over 500 HP when it was a street machine and now that it is in the low 10's making well over 600HP I would say the cast crank is holding up pretty good. I'm running 6.8 Eagle H-Beams and J&E's. Shift at 5800 and go thru the traps at 6,000.
I would say for a street car with 450 HP or less a cast crank should work fine and last a long time.
Tim Corcoran |
Are you sure? All of the 455s that I've seen had 3.25 mains and a 4.21 (at .060 over) bore and a 4.21 stroke, unless it was offset ground to make the 4.25.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 |
I had the machine shop that I use do the extra machine work and assembly.
When I bought my rotating assy from KRE, an Eagle forged crank wasn't available. This was like '08 or so.... Mine is a cast Eagle crank with the 6.8" rod with a 3.25", 2 bolt studded mains. I wouldn't be too concerned with spinning a cast crank(well, I do have the light weight Ross pistons and pins) and I shift it at 6500 just about everytime I've had it out... 30 passes or so at the track and under 800 miles since I put it together... Maybe I'm lucky yet I do remember about a month after I had my motor up and running the forged crank came out... If I had to do it again, I would go with a forged crank even though my cast crank has done well... My 2 ¢... Mike
3.5 was a typo, 3.25 main journals of course. Yes it was/is a 4.25 stroke, I did say it was stroked didn't I?
Tim Corcoran |
