Old 12-22-2012, 04:56 PM
RedDirtRoad RedDirtRoad is offline
Default Steering column and horn
My final assembly is almost complete.
My horn is not working.
I wrung out the wiring and it seems the green wire going back to the steering column has continuity but not completing the circuit.
The plastic turn signal cancelation ring doesnt seem like its making contact with the copper plunger in the turn signal switch
I posted up some pics.
Is something incorrect? should the ring be seated in the column further?
ID:	307002   Click image for larger version
ID:	307003   Click image for larger version
ID:	307004   Click image for larger version
Old 12-22-2012, 11:37 PM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
I would say you have the wrong cancelling cam. There should be a place for the horn contact to sit in. There also should be a spring that sits on top of the cam to give the springing effect so the horn button is off the contact when not depressed.
Scott
If you always do what you always did
You always get what you always got
Old 12-23-2012, 02:19 AM
BOB VIDAN BOB VIDAN is offline
Whats the part number on the cancelling cam, I'll check the number for you?
Old 12-23-2012, 02:56 PM
GT182's Avatar
GT182 GT182 is offline
Is it in upside down? Looks like it to me.... but it could be the wrong cam to begin with.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 12-23-2012, 06:23 PM
Bob,
The part number is 9787616
I included more pics too
ID:	307068   Click image for larger version
Old 12-23-2012, 06:42 PM
Jeff Hamlin's Avatar
Cam looks right, Do/did you have the metal contact plunger in the tube your finger is on in last pic?
Old 12-23-2012, 06:58 PM
Yes Jeff,
Its the white wire coming from the horn buttons with a spring on iton the sterring wheel. I am using the deluxe wheel.
Seems like the cam needs to slide down the steering shaft in the column to press on the copper plunger thats on the turn signal switch but it cant slide down anymore.
Old 12-23-2012, 08:49 PM
Try some lubricant on the copper plunger to see if it frees it up to make contact with the cancelling cam. A good lithium grease should work?
Scott
Old 12-23-2012, 09:14 PM
Plunger is free and all the way out. The canceling cam isnt making contact with the plunger.
Old 12-23-2012, 09:58 PM
Is that the cam that came with the car? Did the horn work when you got the car?
Scott
Old 12-23-2012, 11:25 PM
That's the right number for 67 w/o tilt, looks right for your car. Here's factory installation pictures, might help.
ID:	307098   Click image for larger version
Old 12-24-2012, 10:22 AM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
It could be that the steering shaft needs to be adjusted forward in relation to the rest of the column. How big of a gap is there between the steering wheel & the column? If the gap is too large, you'll need make a minor adjustment & re-set the clamp on the shaft in the engine compartment.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
Old 12-24-2012, 01:39 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Make sure that when you ground the plunger (that mates with the underside of the turn signal cam) that the horn blows. If you don't get the horn to blow then you may have a grounding issue. Basically when the horn button is pressed, ground goes from the main steering shaft to this plunger.
Do you have the little plate installed at the other end of the column that grounds the center shaft? It fits into the rubber rag joint and supplies ground to the shaft from the steering box. You should be able to take a screwdriver from the main shaft to the plunger and get the horn to blow. Then I would be worried about the proper assembly of the cam.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 12-25-2012, 10:02 PM
gomowgto gomowgto is offline
I had the same problem with mine. With the canceling cam removed, grab hold of the plunger that is in the steering column and pull out on it. You willl problably find that the spring inside the plunger has weakened and the plunger isn't coming completely out causing it to not make contact with the back of the canceling cam. I had to remove the turn signal and the spring is held in with a piece of metal that is pressed into the plastic. I pried that out with a screwdriver and replaced the spring with a new longer one, and that took care of my problem. Hope this helps and that is the problem.
Old 12-26-2012, 07:20 AM
Arrow CAM PLUNGER
Just to be clear of which plunger I was referring to;
Old 12-26-2012, 08:43 PM
Problem solved
thanks to everyone for your help
Old 12-26-2012, 10:50 PM
Singleton Singleton is offline
Originally Posted by RedDirtRoad View Post
Problem solved
Well...don't leave us hanging, what was the solution?
It's like I just read a detective novel only to find someone ripped out the last page.
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 12-27-2012, 01:15 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
X2. Would like to know how you solved the problem
Thanks!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 12-27-2012, 01:56 AM
65Mark 65Mark is offline
The butler did it
Old 12-27-2012, 09:12 AM
Well and the solution was???????????????
Scott
