Old 02-06-2013, 08:37 AM
Sebro1231 Sebro1231 is offline
Default 69 allignment specs anyone know?
Need to line up 69 convertible gto. Can anyone provide the specs for this?
Old 02-06-2013, 12:43 PM
dwood1 dwood1 is offline
Here is a copy of a repair manual. I don't like the idea of calling for neg castor. I think it would make the car less stable at speed. Castor aids in many things and one of them is tire stability (straight tracking). Neg is what the car handles like driving backwards. I would be inclined to put 1 or two degrees positive castor in it (I like more)
Old 02-07-2013, 01:05 PM
Thanks for the info and insight!
Steve
Old 02-07-2013, 01:12 PM
geeteeohguy's Avatar
I do the same thing with my goats....about a degree or two of caster. Too much gives you harsh road feedback thru the steering wheel, though, with these cars. One must also remember that the original specs are for skinny bias ply tires, not today's modern wide radials, and the specs were for ease of driving/parking, not driving aggressively.
Jeff
Old 02-07-2013, 04:26 PM
I think the slight negative caster was mostly for ease of turning with manual steering, they should have had different specs for PS... but they didn't.
Old 02-10-2013, 12:46 PM
Verdoro 68's Avatar
Not sure if this will help, but here's how they aligned my '68 the other day. I'm sure others will have better recommendations, but it seems to drive better than before.
BTW, for anyone who hasn't done the Jeep steering box upgrade yet - do it! So much better.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-10-2013, 01:54 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
What is the jeep steering box up-grade?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 02-10-2013, 02:15 PM
Verdoro 68's Avatar
You can replace your stock PS box with one from a mid-late '90s Jeep Grand Cherokee. Much faster ratio and tighter feeling. I took out a fast ratio rebuilt Cardone box in favor of the Jeep box - huge difference!
More info: http://forums.maxperformanceinc.com/...d.php?t=685111
Ken
'74 Ventura 350
'69 AMC Javelin SST
