Old 03-28-2013, 07:12 PM
1966geeto 1966geeto is offline
Default Headers hitting control arm bolt
Have a set of Doug's long tube headers that I have finally been able to do my mock up with eng in the car.The dr side header is hitting the rear control arm bolt I bought the car in pieces but the headers were still in the box the part number is correct for 66 GTO with d port Edlebrock heads.Anyone run into this the part number is d567 . I removed the rear control arm bolt and it looks like it will need to be cut at least a half an inch will this leave enough room for alignment shims the car has no shims in it now have been doing a complete frame off restoration.
Old 03-28-2013, 07:56 PM
Sorry posted in wrong forum..
Old 03-29-2013, 06:49 AM
Too Many Projects's Avatar
Too Many Projects Too Many Projects is offline
I cut mine off for headers too but haven't gotten to alignment yet. The bolts are rather short for any drastic shimming needs. Might be a good excuse to go to tubular upper arms for better handling and less shims now...
Mitch
67 GTO...Gulf Turquoise w/Black bench and 4 speed...
Follow the resto in pics here...http://s1357.beta.photobucket.com/us...28454765976114
67 Camaro ss/rs 350
66 Chevelle SS 396
70 Chevelle SS 396
Old 03-29-2013, 10:39 AM
geeteeohguy's Avatar
I would not cut the bolt. BTDT. Not a good idea. These cars can require shim packs an inch thick. On my old '66 with different headers, I used a ball peen hammer and blacksmithed the header. A small divot was all that was required. I would much rather modify the exhaust to clear the suspension than the other way around.
Jeff
Old 03-29-2013, 01:27 PM
These are ceramic coated I used a 32oz deadblow all it did was a small peen.
Old 04-03-2013, 07:30 PM
ligoatpar's Avatar
ligoatpar ligoatpar is offline
Default header fit
Unfortunatly the ball peen hammer is probably the better fix. They do make offset control arm shafts to help with alignment.
Old 04-04-2013, 09:17 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Try turning the bolt around so the nut is to the inside.
I don't know about factory a-arms but this fix was mentioned in the instructions of my aftermarket tubular control arms, I did it but have not had aligned yet.
Turning the bolt around and a smaller dimple might do the trick.
If the springs are already installed, you would have to compress/disassemble the springs to safely remove the bolt.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
Old 04-04-2013, 10:45 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
I don't know what the '66 A-bodies look like for ability to shim and clear on the a-arms, but on my x-body Buick I cut my A-arm bolt years ago and still have ~1/4 of threads showing and a ton of header clearance. The car has always tracked straight and is in perfect alignment now.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 04-04-2013, 07:08 PM
Thought about turning bolt around my frt end guy would probably kill me when he went to align frt end the bolt is supposed to be staked to the frame so it does not rotate when installing shims I used to hate it back in the day when I went to do an alignment and the bolts twisted also looked at adjustable control arm but not in the budget right now.
Old 04-05-2013, 12:29 AM
rontiac's Avatar
rontiac rontiac is offline
I'd just cut the bolt! If you need 1" of shims.....you may have other issues! Besides, you can always get another bolt. JMO...
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
Old 04-05-2013, 01:26 PM
Geeto, you are dead right about not turning the bolt around. It's spined to the frame (like a hub bolt) to keep from turning, and if you turn it around, the alignment will be a PITA, and you could end up damaging the splines in the frame rail from the bolt not being anchored and held in place as it should be. Not a good solution, IMO. Modify the header tube, IMO.
Jeff
Old 04-08-2013, 08:02 AM
chrisp chrisp is offline
Make sure engine / trans. mounts are good / as well as the trans cross-member end bushings , install new if in doubt , if the engine is not sitting properly that could be your problem .
Old 04-08-2013, 04:55 PM
Everything is new including all body bushings trans mount and cross member mounts complete frt suspension rebuild called Doug's they said they should bolt right in baffled .
Old 04-09-2013, 08:55 PM
leeklm's Avatar
leeklm leeklm is offline
"said they should bolt right in"
Sorry, I am of no help here, but your quote above made me smile this evening
Old 04-10-2013, 01:20 PM
cfd2bc's Avatar
cfd2bc cfd2bc is offline
I cut mine off as well to fit. I took it to get aligned and had no issues. Actually there is quite a bit of thread left for adjustment on mine.
Old 04-10-2013, 08:43 PM
It'll only take a few minutes was my next guess lol..
