Old 03-29-2013, 05:59 PM
carpoor carpoor is offline
Default Disc brakes with factory wheels... fitment?
My father is dead set on doing a disc brake conversion. (66' GTO) It has factory 14" Rally I wheels. I do not want to replace the wheels, trying to keep this car as original in appearance as possible. I haven't had the time yet, but was going to remove a wheel off of the car and try it on the front of his 72' Lemans to see if it will clear.
Seeing what others have used on their own cars of this vintage. Thanks in advance.
1972 Chevelle SS 2dr hardtop 454 LS5 4 spd - "Pure Stock"
1969 Chevelle 2dr hardtop L72/M20 - my "retirement" project.
1968 Chevelle 2dr hardtop 6.0/80E - pro tour-ish
1972 Monte Carlo turbo 6.0/TH400
2001 Silverado RCSS LQ4/80E swapped, cam, headers, FBO.
1972 E lCamino SS AFR headed 454/TH400 - the old man's project
Old 03-29-2013, 06:14 PM
jd66 jd66 is offline
My 66 has disc brakes from a late 60's early 70's A body car and the original rally 1 wheel fits, there close but do fit. jd grim 66 gto
Old 03-29-2013, 07:32 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
I put discs from a 71 Monte Carlo and my 14" rally ones fit just fine. I hear most aftermarket kits need 15" wheels.
Mitch Kunath
Old 03-29-2013, 07:33 PM
GoatandBirdCollector GoatandBirdCollector is offline
Had my '66 converted a few years back from standard drums to front power disc and was able to keep the factory Rally I's.
It's tight, but no problems so far.
Old 03-29-2013, 11:01 PM
GT182's Avatar
GT182 GT182 is offline
As Mitch said most require 15" wheels for the conversion. There are kits that will let you use 14" wheels, but you'll have to search for them or get used disc brake parts off a car that has stock 14" wheels.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-30-2013, 12:36 AM
The old dual piston calipers from 67 and 68 i think were the ones that could cause interference with some 14" wheels.
They used 2 different Rally2 codes in 67-68 depending if it was drum or disc.
Old 03-30-2013, 10:32 AM
GT182's Avatar
What year did Pontiac switch to 15s as the standard size wheel? I know that my 71 Camaro still had stock 14s.
Gary
Old 03-30-2013, 12:22 PM
xkeots's Avatar
xkeots xkeots is offline
I just bought a conversion kit from OPGI to convert my front wheels to disc brakes and the 14 inch Rally 2 wheels will fit.
It comes with all parts needed.
Look it up.
Good Luck
Jack
Old 03-31-2013, 10:27 AM
GT182's Avatar
I've seen them Jack but wonder why the upper control arms are included in the kit, and no disc brake backing plates are included. Usually the disc brake spindles are included too. CH28689 and CH28690 kits.. correct?
I do know the original drum spindles must be modified too for the changeover.
Gary
Old 03-31-2013, 12:33 PM
xkeots's Avatar
No upper control arms, those are caliper mounts.
I bought the CH28690 for power brakes. CH28689 is for non power.
Backing plates I am not sure about as everything is still in boxes till it gets above 50 degrees outside.
I bought every suspension part brand new (except torsion bar) , so my car should ride and handle like a new 67 with front discs when done.
Jack
Old 03-31-2013, 08:54 PM
GT182's Avatar
When you get to it to do it keep us informed... with pictures. I'm planning on doing the conversion too, hopefully sometime this summer. But no power brakes... tho hydro boost might be in the cards for the future.
Gary
Old 04-02-2013, 09:18 PM
HaloMedic's Avatar
HaloMedic HaloMedic is offline
Give Scarebird http://www.scarebird.com/
a pm im sure he will be able to set you up he is a member of PY and has a great product
Let me know how you make out with him
I didn't use his stuff on my 66 GTO only because I had already purchased a SSBC I would have saved a lot of cash with Scarebirds Product
I set my car up both ways for what ever mood im in and for car shows
so with the SSBC I had to buy a set of 15 cragers for the front was already running 15 in the rear 14 in the front
and a set of 15 rally 1 with tires so you can see the savings added up quick
Break down I would have saved nearly $1500.00 going with Scarebird
Gentlemen put your trust in God, But mind to keep your Powder dry. Oliver Cromwell
Michael Hughes Sr
1966 GTO Convertable: Stolen never recovered
1966 GTO Hard Top .30 over 455 4-Speed 3:23 Posi
Old 04-02-2013, 10:14 PM
old66tiger's Avatar
old66tiger old66tiger is offline
Buddy of mine used the Right Stuff kit on his 68 with factory original Rally 2's. Had to grind the mounting bracket down a tiny bit and they work fine. No problems. I would assume Rally 1's to be the same deal
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 04-03-2013, 08:07 AM
SD421's Avatar
SD421 SD421 is offline
I am using Scarebirds disc brake setup and even though I have yet to actually drive my 1966 GTO, my 14" wheels clear the calipers.
-Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 04-03-2013, 12:26 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
I can confirm that they fit with rally 1's after the minor bracket grinding mentioned above.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, next project
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
