Old 04-01-2013, 03:43 AM
firstyearta's Avatar
firstyearta firstyearta is offline
Default Trunk Light Wiring
My '73 Formula has an optional trunk light. I know the wires run through the lid, but where does it enter the body and where does the harness connect?
And how do these work to turn on and off? Is there some sort of internal mercury switch in the light?
http://i27.photobucket.com/albums/c168/firstyearta/67side.jpg
Old 04-01-2013, 11:23 AM
FunctionalShaker FunctionalShaker is offline
The wire hangs down through the trunk opening and connects to the tail light harness behind the rear seat. I believe it is a mercury switch.
Old 04-01-2013, 07:24 PM
mscicluna007's Avatar
mscicluna007 mscicluna007 is offline
Default Picture
It enters the boot lid at the hole in the lower left and their is a plastic retaining clip that attaches also.
ID:	318250   Click image for larger version
Old 04-03-2013, 11:40 PM
Thanks for the pictures. Very helpful.
Old 06-23-2026, 05:38 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Sorry, dragging up an ancient one.
I have a trunk light wire assembly. Trunk end of the wire terminates with a male end clip. How does it connect to the tail light harness? I see no provision within the harness.
Do most simply splice into a constant 12v source (ex. dome light white wire).
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 06-25-2026, 01:51 AM
Formulabruce's Avatar
Connects to the end of the harmonica connector which is attached to the trunk hinge brace on Drivers side.
" Long may we DRIVE !"
Old 06-25-2026, 01:55 PM
hojs69's Avatar
Thanks.
Looks like there is a plug for it after all on the "end" of the dome light connector (from the two white wires).
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
