Old 04-05-2013, 12:00 PM
SD73's Avatar
SD73 SD73 is offline
Default 1970 Fat Wheel ID or Repro?
Hello guys, I'd like some help to properly identify this wheel. Can anyone let me know if this is a valuable NOS and I quote:
"NK-3 Wheel for a 70 1/2. Called a thick rimmed wheel"
or
a common repro.
It has a dull finish with a grain texture. It's much firmer and more plasticy feeling than later wheels, and it has some sort of molding line around the circumference of it.
Any pictures of Actual wheels from that year or repro wheels would greatly help if you have them!
ID:	318654   Click image for larger version
ID:	318655   Click image for larger version
ID:	318656   Click image for larger version
ID:	318657   Click image for larger version
Old 04-05-2013, 12:04 PM
SD73's Avatar
A few more pics...In the last couple you can make out the molding line.
ID:	318660   Click image for larger version
ID:	318661   Click image for larger version
ID:	318662   Click image for larger version
ID:	318663   Click image for larger version
Old 04-05-2013, 12:51 PM
tdavidl's Avatar
tdavidl tdavidl is offline
check out post #13 for two links w/pics:
http://forums.maxperformanceinc.com/...+formula+wheel
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 04-05-2013, 04:46 PM
SD73's Avatar
Thanks for posting David. Lots of good info. This wheel does not have the "IC" at all. So can I assume that would automatically preclude it from being a 70/71 wheel. It also doesn't have the "race track mold pattern" described in the back too. Would the grain, dull appearance, and firmness on the wheel positively identify the wheel as a repro?
Old 04-05-2013, 05:16 PM
Held for Ransom's Avatar
Grain pattern looks repro to me.
Old 04-05-2013, 05:32 PM
Norwood's Avatar
Norwood Norwood is offline
repo for sure..
Old 04-05-2013, 09:17 PM
njsteve's Avatar
njsteve njsteve is offline
Repro wheel. The area where the rubber material ends and the spoke begins is way too sharp of a cut on the repros. On an original wheel it is a gentle curve inward to the spoke. Also the material is way too hard and the grain is way too distinct on the repro.
