1982-1992 TA & FB parts WANTED 1993-2002 TA & FB parts WANTED is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 04-29-2013, 09:51 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Default Wanted: T5 transmission on the cheap.
I want a T5 transmission on the cheap to install behind a naturally aspirated inline 6 engine. Cheaper is better. Needing rebuild is okay if cheap enough. If a Mustang one I'll figure out what I need to do to make it bolt to the GM bellhousing and work with a GM engine. Its for a temporary install, a year or so, so I don't want to spend a ton on it.
What do you have? Thanks.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 04-29-2013, 10:26 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
I'd check your local Craigslist.com ad's. Most T5's are broken because they simply didn't last long behind anything.
Old 04-29-2013, 06:48 PM
Did that while in CA for So. Cal, Las Vegas and for Elko (185 miles from here), and there were better deals on E-bay.
I figured as you mention since they don't last long behind anything, some one here might have one as a door stop from an upgrade.
Old 04-30-2013, 09:13 PM
Cammer-6 Cammer-6 is offline
I have a couple tubs full of T5 parts but shipping is probably more than its worth.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-01-2013, 07:56 PM
Nothing complete? E-bay implies shipping can be around $100.
