Old 05-19-2013, 07:30 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
Smile CURRENT COMBO CAPABILITY III
Well after all these years i finally went to a real drag strip, sacramento raceway. i had only run on a dragstrip two passes at an old drag strip/ airport that they use once a year. my TA ran 14.65@ 94.24 so i was pretty happy. friday night it ran [email protected] on the first pass. and [email protected] the second.it spun the mickeys a little on pass two. pass three was [email protected] and it spun pretty good on the line. now i have a total of five passes on the drag strip. my 455 is the L75 engine with 8.0 comp gm 068 1.6 rockers ra exhaust 2.5 pypes subframe connecters and q-jet by me, after reading two books. LOL i got on wallace racing and pluged in the numbers for the 98.47 mph and it says yhe car should do 13.60 or 13.50. i had soooo much fun you couldnt wipe the smile of my face! just thought id post this info, that even low comp 455,s rock!! thanks for all the info i,ve learned on this site. and i love my PONTIAC. BLUE TA
Old 05-19-2013, 08:04 PM
Beebe's Avatar
Beebe Beebe is offline
Too Cool!! One of the Best Feelings in the world!
What was some of your 60ft. Times ? More than likley this is where you will pick up some time.
I heard drag strips in california are like almost extinct?
Beebe
Also Known As "Beebe" on other sites....... PZ , Pro-Touring , Lateral-G, TAC
Old 05-19-2013, 08:36 PM
grrrrregg!!! grrrrregg!!! is offline
COOL, glad you had a good time. Good to have another Pontiac at Sac Raceway. Hope to see you there sometime.
Old 05-19-2013, 11:05 PM
66bonne's Avatar
66bonne 66bonne is offline
Good times for the car and you !!
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 05-20-2013, 01:13 AM
hal101's Avatar
hal101 hal101 is offline
sounds like you had a great time
i mist the year
what trans
what rear gears
Old 05-20-2013, 06:49 AM
rad400 rad400 is offline
Blue good job man. Racing is alot of fun.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 05-20-2013, 07:35 PM
BLUE TA's Avatar
Hi Guys, thanks for the nice words. beebe, yes your right the 60 ft times were 2.12 best and 2.16 worst. i was suprised i spun the mickeys the second and third passes. i had 21 lbs. in them, maybe im off on that? the car wieghs 4050 with me in it. th 400 3.08 posi. the center of the tire didnt look like it was wearing much. more air? i also was only running 30 degrees total timing, maybe with the 8.0 comp. i should be 32-34 degrees? grrrrreg, my ta is a 74, what pontiac do you have? ill watch for you next time! 66 bonne thanks, i,ve always liked your car! BLUE TA
Old 05-20-2013, 10:30 PM
ta man ta man is offline
Try down around 18 for the Mickey's..30 degree timing is low...my 76 low compression 455 I'm at 38..Next time at the track put the timing up 2 degrees at a time...or crank it up at home...you will feel a huge difference over 30...Just double check it doesn't advance at higher rpms.You have a stock convertor too?Pretty good times I think!
Old 05-21-2013, 08:40 AM
right now I'm between cars, I used to race a black 69 GTO, years ago I had a 10 second 64 GTO. Hopefully around the beginning of the year I'll be back out with a 71TA. I still go out there with friends, what color 74.
Old 05-21-2013, 07:50 PM
BLUE TA's Avatar
Hi grrrrreg, its the Admiralty Blue code 29 i think chevy called the same color midnight blue. BLUE TA
