Old 05-23-2013, 09:05 PM
ironman ironman is offline
Default Fuel Pump
Looking to run an electric fuel pump in my 68 firebird, 455 with a Quadrajet. Need advice on pressure I don't want to run a regulator if i can avoid it. Looking at the carter P4070 or P4594 suggestions on what one I need.
Old 05-23-2013, 09:18 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default fuel pump
went with the airtex from autozone. was around 25 bucks and has been trouble
free and correct pressure. i run a return line and this was am exact fit.
gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 05-24-2013, 05:43 AM
68WarDog's Avatar
68WarDog 68WarDog is online now
IMHO, deadheading a street car is asking for trouble. OK for race where continuous use is a non-factor. I had a deadheaded system(mallory 90gph) on a street/strip car several years ago. Hated it.Alot noisier than a return system and the pump generated excessive heat(wear ). Even OEM deadheaded system had there drawbacks(vapor locking).BUT IF you do decide to go that route I would prefer one of the quality Aeromotive pump, just not sure if they offer one(self-regulated) without a return.
Old 05-24-2013, 06:39 AM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
X2 on the return line. On my 76 TA 455 I installed a new tank with a new RobbMC 1/2"pickup, Jeg's pump kit with braided lines,fuel filter, 130GPH pump and a deadhead regulator. The pump within a few minutes would start losing and fluctuate it's pressure do to being deadheaded. I called Jeg's to complain, and they sent me a new pump and a return style regulator at no cost. I had to plumb a return line, but now the car has no fuel issues. It no longer runs out of fuel, pressure remains constant, the car now idles smoother and runs better than it ever did. This was an expensive system, but I really like it and it looks and works the way I had hoped when I started the changeover.
Old 05-24-2013, 07:24 AM
Tim Corcoran's Avatar
What is wrong with the factory AC Delco stock replacement pump? Are you sure you even need an electric pump?
Tim Corcoran
Old 05-24-2013, 07:51 PM
carby emptying over night takes a while to wind engine over on first start up to fill carby thought an electric pump may cure this, could it be a problem with the existing pump, it is an aftermarket item of unknown brand or breed?
Old 05-24-2013, 09:26 PM
Default Carb
Sounds like a carb issue and not fuel delivery.
I can let mine sit for a week and she will fire up
After a second or two.
Find out where the fuel is going.
Gerry
Old 05-24-2013, 10:37 PM
Chris-Austria Chris-Austria is offline
RobbMC has everything you need. I'd run the mechanical fuel pump with vapor return. Easy install and works great. Without the vapor return (Edelbrock 1713 pump) I ran into vapor lock pretty soon. Maximum pressure for a qjet will be about 6-7psi
Old 05-25-2013, 09:35 AM
You don't need an electric pump. You just need to fix your carburetor. Why spend money on something you don't need just to bandaid something else that needs to be fixed. People are always anxious to install an electric pump and in many cases it's a waste of time and money and is noisey. An electric pump also adds a fire risk bacause if your carb float sticks open your pump will just keep pouring out the fuel and flood the engine with fuel and one spark or engine backfire and you have quite a situation on your hands. Ask me how I know?
Tim Corcoran
Old 05-25-2013, 10:19 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Q-jet well plugs are known for leaking all the fuel out of the bowl over night. There is a procedure for repair in cliffs carb book.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 05-25-2013, 11:30 AM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Also check to see that the check ball in the well next to the accelerator pump is sealing. I made a new seat and it cured my problem.
http://forums.maxperformanceinc.com/...d.php?t=721097
Karl
Old 05-26-2013, 08:39 AM
arrowem's Avatar
arrowem arrowem is offline
Qjets are known to do that. Mine is built by Cliff and still does it. I'm not sure if it is as fast as over night but two days for sure. I have a RobbMc 1100 pump and regulator with return.
'68 Firebird
-Before you press that thing to the floor, be sure you're right with God....
'68 hard blocked forged 463 (thanks Luhn Performance), SD prepped HO aluminum intake, SD Perf 290cfm KRE'S,'Ol Faithful cam, 2004r with a "Jim Hand special" converter to a 3.42 Trutrac 12 bolt hung from a 4 link. With a 120 shot of N2O for fun.
