Old 06-12-2013, 04:31 PM
mogeo's Avatar
mogeo mogeo is offline
Default diff between 68 and 69 seats
I need to replace the seat foam in my car. The orig owner said he swapped the seats out from a 69 years ago.
They are headrest seats currently.
Without taking the seats apart and uncovering them , how can I tell if they are from a 68 or a 69?
Old 06-13-2013, 04:33 AM
Tim john Tim john is offline
Pattern of material. Look at a PY or Ames catalog / on-line and compare the seat pattern for the year difference.
Tim john---
Old 06-13-2013, 07:56 PM
Cammer-6 Cammer-6 is offline
tops are same its the buns(lower) that are wider on the 69
If you want to retain headrests(2 different styles in 69)
use the upper part of 69 seat and lower part of the 68.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-08-2013, 12:45 AM
Kurt S Kurt S is offline
Not sure how different 67/68 F-bird headrests, but here's a bunch of info:
http://www.camaros.org/headrest.shtml
Kurt S
CRG - Camaro Research Group
The Following User Says Thank You to Kurt S For This Useful Post:
Old 09-08-2013, 09:17 AM
chrisp chrisp is offline
67 -69 seats are all the same weather from a camaro or firebird , the difference is in the foam where the cutout is for hog ringing the center area to pull down . Order the correct year / pattern / foam buns for your car and all will be fine . 69 seats are not wider than 67-68 .
Old 09-08-2013, 01:13 PM
rickschabener's Avatar
rickschabener rickschabener is offline
I don't believe any 68's had headrests.
Rick
Old 09-08-2013, 01:51 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Early 69's had straight bar headrests after that they are curved.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
The Following User Says Thank You to PMD1969 For This Useful Post:
Old 09-08-2013, 02:20 PM
68tpls400 68tpls400 is offline
Yes, they were (a rare) option. I know two people that have them in their cars too.
Old 09-08-2013, 08:10 PM
actually 67 and 68 both had headrests as an option
Old 09-09-2013, 01:47 AM
Yup, I just haven't seen the 67/68 Firebird headrests to confirm they are the same as Camaro. I suspect they are.
Kurt S
Old 09-09-2013, 08:46 PM
try putting a 69 bottom seat cover on a 67-8 (or vice versa)and tell me that again
Old 09-10-2013, 09:24 AM
You need some comprehension , steel frames are the same , the difference is in the seat foam / buns / skins . Have done it 1/2 dozen times .
Old 09-10-2013, 09:20 PM
I have no problem with my comprehensive skills.
I do have a problem with my mind reading skills tho.
You forgot to include a key part so Ill quote your last clarification
"steel frames are the same"
Old 09-11-2013, 08:38 AM
Next .
