Old 07-09-2013, 05:05 PM
Peje Peje is offline
Default 1969 Alternator Markings?
Just been restoring a 1100704 Alt for my GTO.Should there be any "inspector markings" on the alt?
Old 07-09-2013, 07:25 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
The two letter alternator code should be stamped on the case with black ink.
The code is XB for the 55 amp alternator and XC for the 40 amp alternator. You can have
the stamp made at an office supply or you can buy one from a Pontiac parts vendor.
Old 07-09-2013, 08:17 PM
stellar stellar is offline
Hi Peje. I see them on ebay also. Some of the ebay sellers will make the letters you need.
Old 07-10-2013, 02:56 AM
Thank you guys and Hi Stellar! 40 amps=37 amps version?
Need to change one stator and planning to use from a 1100794.Same Sh**t?
Old 07-10-2013, 06:20 AM
Yes 37 amps for both numbers. Same parts so use the 794 stator.
Old 07-10-2013, 07:12 AM
Hi! Thanks for info.It`s alt nr 2 I´m working on.Anybdy have a picture of the marking? Such as placement,size of the letters etc,etc.
Old 07-10-2013, 10:11 AM
Go to Google search and type in Alternator stamp then click on "images"
Tons of photos of these stamps will come up on your screen.
Old 07-10-2013, 12:12 PM
Thanks! There were a lot!!
