WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 General Tech/Discussion
93-02 General Tech/Discussion 1993-2002 Firebird/Trans Am General Tech/Discussion
Old 07-14-2013, 12:21 PM
Default Air conditioning
Air conditioning isn't as cold as it should be. The car is only used in this area for a few months out of the year and it apparent that its leaking. I don't think the air would even be used all that much. After all it is a vert and I don't take it out unless I can drive with the top down.
Is it possible to recharge it with a can of what ever I can get at the auto parts store to get by from season to season?
Old 07-14-2013, 06:39 PM
Cammer-6 Cammer-6 is offline
depends on how much it leaks to see if its worthy of a leak fix
what ever you do dont use any fix-it-in-a-can.
I dont like just dumping a can in without seeing what the system pressures are.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-15-2013, 02:16 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
What I did with mine is take it to a pepboys when they advertise the 20$ AC quick check, they put a leak detector on it, and refill it, you drive around for a week then take it back and they see where its leaking
this way you know how bad the leak is and how much refrigerant it loses per week
plus its cheap
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Featured Vendors
Advertising Info
