Old 09-22-2013, 11:30 AM
shawn e.'s Avatar
shawn e. shawn e. is offline
Default 68 Lemans Transmission ID
Gave my son a 68 LeMans I bought a few years back and need to get it road worthy. Truth is I have yet to even crawl under the car. What automatic transmission is in a 68 Lemans, 350, shifter on the column? And what is a direct replacement?
Thanks Shawn
"Don't let fatigue make a coward of you."
Old 09-22-2013, 05:28 PM
Easy if it's original.
Look on the shifter read out.
If it has 3 speeds on it - D, S, L it's a 350 Turbohydromatic
If it has 2 speeds on it - D, L then it's a 2 speed tranny, (Tempestorque?)
Anyway, if it's a 2 speed, a TH350 should bolt in easy enough, other than the column shifter would need changed.
A TH400 could bolt in but the driveshaft would have to be shortened or changed to a TH400 one. Also, the crossmember will probably need changed, along with the column shifter.
Old 09-22-2013, 07:04 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
2-speed is officially the ST300, not a powerglide - there are no interchangeable parts between the two!
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
The Following User Says Thank You to 68gtoMN For This Useful Post:
Old 09-22-2013, 08:12 PM
stevep's Avatar
stevep stevep is offline
THM 350 was not introduced until 1969, so if it does have one, someone added it and if they did, thank them! If it is the original ST-300 2 speed, the THM 350 is a direct bolt-in.
The Following 2 Users Say Thank You to stevep For This Useful Post:
Old 09-23-2013, 07:02 AM
And Steve is correct.
Old 09-23-2013, 09:05 AM
shawn e.'s Avatar
Thanks guys!
Shawn
