Old 10-25-2013, 11:53 PM
phk1967 phk1967 is offline
Default HEI swap now car won't start
I just swapped a Unilite for an HEI in my 68 GTO now I can't get it started. I removed the resistor wire from bulkhead and ran a 14 g wire from there to hei cap and spliced a wire from the solenoid to that same wire. I get little over 12v in run and during cranking it's almost 11, I am currently still using same E3 plugs . I double checked the wire routing and that I installed distributor correctly, at tdc of #1 compression stroke all is good. I thought I might of had a bad module so I changed and it still won't work. Someone told me that with the original externally regulated alternator set up it would fry the modules ? I get spark my timing light is lighting up and I have fuel, flow is good from fuel line and into carb. I'd appreciate it if anyone has any ideas I tried everything I could think of and I'd like to get her going before winter.
Thanks!
Old 10-25-2013, 11:58 PM
dmac dmac is offline
If you are getting spark, I would recheck the firing order for the plug wires. HEI also had different plug gap. You should be able to run with no alternator or regulator. Suggest wiring directly to battery with everything but fuel pump (if electric) disconnected to determine if HEI is bad..
Old 10-26-2013, 12:02 AM
67cruiser 67cruiser is offline
Don,t forget wires go in counterclockwise. 18436572
The Following User Says Thank You to 67cruiser For This Useful Post:
Old 10-26-2013, 01:18 AM
lust4speed's Avatar
Since your timing light is flashing, make use of it and see where your timing is. It really doesn't take the distributor being off much to not fire off the engine.
Nothing to do with your current problem, but I personally would replace the 14ga wire with 12ga.
Mick Batson
Old 10-26-2013, 10:43 AM
Icefan71 Icefan71 is offline
X2. Your timing may be off just a hair.
1972 Pontiac Lemans 350 Qjet Summit 2800
Old 10-26-2013, 11:05 AM
ELKHORNAOG7 ELKHORNAOG7 is offline
Question
You may want to check and make sure you are on the comp. stroke for # 1 cyl. if not you will have to set your wires for # 6 cyl.-----BOB
Old 10-26-2013, 12:01 PM
Gentleman thanks for your input I'll go thru and check everything all over again and try some of your ideas and see if it won't fire up.
Old 10-26-2013, 07:59 PM
I must have a wiring problem. I checked plugs for spark with a plug tester all seemed good then hooked up timing light , didn't work?, hooked it to my truck and it worked fine.
Could it be the way I have hei wired up. I removed the cloth covered wire from bulkhead and replaced it with 14g wire, I then spliced a wire from R on solenoid into that as my power wire, did I goof up with the wiring to the HEI ?
Old 10-26-2013, 08:42 PM
Firebob's Avatar
Firebob Firebob is offline
You should only need one 12v wire going to the dist. The one wire to the solenoid should be coming from your ign switch. Some systems were wired with a second wire from the solenoid to supply 12v to the dist while cranking but after the key was released power would flow through the resistor wire at a reduced amount so the points wouldn't fry. This is the one you replaced but the second one isn't needed with the HEI. Sounds like you may have something else not hooked up correctly though. Are you sure the coil is good? Sometimes you can get some spark but not enough to fire. It should have a defifite snap when it fires the plug. I've also seen the button inside the cap detiorated to the point that it wasn't making contact anymore. Is this a new HEI?
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 10-26-2013, 10:21 PM
lust4speed's Avatar
Nothing wrong with the wire from the solenoid supplying starting voltage to the distributor. An alternative wiring hookup would have been to bridge Ign-1 and Ign-2 at the switch and run one wire to the distributor. Picking up start voltage from the solenoid works fine.
I wouldn't make too much out of not having your timing light working. Many times an inductive timing light will not fire off at cranking speed. I started my earlier response "Since your timing light is flashing..." because most times mine will not flash until the engine starts up. Checking static timing would have just been much easier if the light had worked.
Mick Batson
Old 10-26-2013, 10:31 PM
I have all new summit parts in the HEI. I'm just really getting stressed caused it won't fire up no matter what I try. I didn't know that about the timing light good info to know. Well back at it tomorrow.
Old 10-26-2013, 10:36 PM
Formula8's Avatar
Formula8 Formula8 is offline
Did you remove the ballast resister/wire?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 10-26-2013, 10:40 PM
tooski tooski is offline
Default No fire
Had same probelem. Changed in cap coil. Fired up.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 10-26-2013, 10:42 PM
Also once had problem with the non stock connectors hooking up to the coil connectors.
Frank M.
75 Firebird
Old 10-27-2013, 12:39 AM
Schurkey Schurkey is offline
Are the plugs fouled?
Simplified HEI diagnosis here:
http://www.chevelles.com/techref/ftecref5.html
Old 10-27-2013, 12:48 AM
Resistor wire is unplugged from bulkhead and all my plugs are clean. Coil is new from Summit but I'll check it, you never know.
Old 10-27-2013, 01:09 AM
I'd try spraying some starting fluid in the carb. If you don't get it to fire, maybe not run but at least fire, with starter fluid, then you have an ignition/spark problem. If you get some firing with starter fluid, but it won't 'catch' then the problem is in the fuel, timing,. but not likely in the coil or HEI, other than timing.
Then I would try running a wire straight from the battery to the dist.
You don't know where the problem is now. If if runs with the direct 12v hook-up but not with the original hookup, its the wiring. If it doesn't run or start or kick over with the direct connection, it's in the HEI, ignition, timing, or fuel. You need a plan to diagnose the actual problem, and not just try everything.
Old 10-27-2013, 07:53 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Talking 12VDC wire!
Darn, thats what I was gonna say!!
I have it wired a little differently, but might help.
I have the original IGN2 wire from the firewall on a relay powering the HEI.
So I have a 12ga wire from Battery on terminal (t) 30
IGN2 wire on T86
HEI power wire on T87
Ground on T85
This is so the key turn the car on and off. This is in 67 Tempest Wagon.
67 Tempest Coupe has a wire coming from battery to a toggle switch. Then to HEI + terminal. Works flawlessly.
That said, I have had many many Pontiac's 180* out so make sure you were def on compression stroke of #1. I like to remove the valve cover when I check.
One last thing, unless the harmonic balancer is new, don't trust the zero mark as it might have spun.
HTH,
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 10-28-2013, 04:45 PM
Thanks guys for all the help. Anyways I had a chance to really get into it today and go through everything only cause the wife was at work. It ended up being a carb problem. I swapped it out and it fired up on first try, now I need go through the carb and fix that problem.
