Old 11-20-2013, 11:23 PM
GTO4spd's Avatar
GTO4spd GTO4spd is offline
Default Engine Unit Number
About 10 years ago I bought a 68 GTO and it immediately went on the back burner. I have been collecting parts and now I want to start the rebuild. The EUN is blank on the Car Billing History, is this a rare occurrence or did it happen regularly? What else can you tell me about this car? I find it odd that it was ordered with a standard eng and automatic with 3:90 gears. Thanks
Name:	68 GTO Billing.jpg
Old 11-21-2013, 08:19 AM
The Boss's Avatar
The Boss The Boss is offline
Not uncommon depending upon the plant. Baltimore will often come up with all zeros in the engine & trans unit number area.
And go racin' in the street.
Old 11-21-2013, 08:26 PM
YS with 3.90 axle is wild
can call that apect rare or low production.
None of the plants "seemed" to follow the EUN posting on Billing History on 68 models until around Dec. Even at that - a couple went to using all 0's in their posting when they did start posting them.
But consider we don't how many BHC's versions were recorded at PMD - as in how many versions of the same document were filed. As in - some version of the same time frame of the document might have it supplied on every car. Where as the particular version we actually get from PHS in some instances has no EUN data or all 0's.
for instance - these documents :
i have a July 5th Baltimore GTO with EUN
then a July 15th Baltimore GTO with all 0's
Inconclusive.
Was likely transcribed to record on all of them by some means or another.
At minimum.
Old 11-21-2013, 08:51 PM
GTO4spd's Avatar
Thanks Boss, Baron. Is there a book/web site that I could go to that decodes all the codes on this document? I know a few of them from the rest of the PHS paperwork. Thanks
Old 11-21-2013, 08:53 PM
The Boss's Avatar
No, unfortunately.
Which ones are you having trouble with?
345 doesn't show up on the order sheet because it's the standard engine - not an option.
Old 11-21-2013, 09:32 PM
GTO4spd's Avatar
No, unfortunately.
I haven't been able to decode block 74. Thanks
Old 11-21-2013, 10:54 PM
We never actually nailed 742 either . iirc
Was thought to be a process code for 754 shoulder belts.
The order sheet with yellow highlights from PHS is best decoder.
If you have clear copies.
Some of the 3's are choice 1 and 2 - combined.
Some 5's are choice 1 and 4 combined.
etc ...
Name:	68 GTO option prices 1.jpg
ID:	344009   Click image for larger version
Name:	68 GTO option prices 2.jpg
Old 11-21-2013, 11:06 PM
You probably already know it was built at Kansas City Missouri plant.
To - From State Codes
are both 24 ..... means it went to a dealer inside Missouri
12 056
12 = St. Louis Missouri Zone
056 = Barton Pontiac Inc 9001 W Florissant Ave St Louis MO
GTO4spd's Avatar
Old 11-22-2013, 09:24 AM
Were front license plate mounts stock on all GTOs?
Old 11-22-2013, 09:36 AM
nytrainer's Avatar
Originally Posted by
[IMG
http://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=344009&stc=1&d=1385088 984[/IMG]
BVZ,
Do you happen to have the same lists for 3767 that you can post? Curious what the 350 HO cost was on the LeMans as I got the PHS but didn't get the window sticker..
