Old 12-29-2013, 02:51 PM
jacskon1970 jacskon1970 is offline
Default Radio help
I have an Audiovox CHT-73mpx that I removed from my 1969 GTO. I know it wasn't an original radio for the car because someone cut the dash trim for it to fit. I can't find any info on this radio and I would like to find out what car this belonged to. Suggestions? Also, I would like to find an original radio for the car.
Old 12-29-2013, 08:30 PM
arcitech's Avatar
arcitech arcitech is offline
Audiovox was/is a low end aftermarket car stereo manufacturer. We used to buy them in the 80's and blast them through 6x9 speakers until something blew!!! Most late 60's early 70's GM cars used Delco radios, I would have to do some searching for the correct model for any particular car. Chances are your wiring harness was cut to splice in the Audovox, so you would need the correct harness end(s) to fit whichever radio you find.
Old 12-29-2013, 08:33 PM
arcitech's Avatar
Here is a good starting point:
http://www.ebay.com/bhp/pontiac-radio
Old 12-30-2013, 09:13 PM
chrisp chrisp is offline
Pioneer super tuner & a set of Jensen coaxials , windows up fire up the doobie . The good ole days .
Old 12-30-2013, 10:32 PM
Audiovox was used in a lot of foreign cars when the new car radio was just an AM radio. We sent our Datsuns out to the local shop to have them put in for little or nothing when the new car customer wanted a better radio. Audiovox I don't believe was ever installed as a factory installed radio.
Old 01-05-2014, 09:27 AM
6TEE8GTO's Avatar
6TEE8GTO 6TEE8GTO is offline
There's a couple AM/FM originals on EB. I've been kicking this around and decided on this one:
http://www.ebay.com/itm/200433100321
I know it's spendy but it will look somewhat correct and I like that it's new, has modern features and plus the guy is a Wisconsinite like myself.
GREG'S GOATS:
1970 GTO Judge
RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970.
1968 GTO
461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's.
1966 GTO Ragtop
4-Speed, AM/FM, Original driveline.
Old 01-05-2014, 04:32 PM
I would keep looking around as there are many other radios & aftermarket radios that look original that are less expensive. I'd look around for a little bit more to save you some money & they do look just like the originals your needing.
