control arm bushings
Hi, I am doing a disk conversion and a suspension kit rebuild to my 66. Those control arms look like a lot of work, how important is it to replace those bushings which i have as a part of the kit.
If your old bushings are dried out and cracked, it'll make a huge difference. Did your car shake, rattle and roll going over railroad tracks? Now imagine going over the same tracks in a new car; thats the difference it makes.
"GTO......Gas, Tires and Overdraft"! '70 GTO convertible, 434, 4-speed |
The Following User Says Thank You to HJones1313 For This Useful Post: | ||
Do it now,huge difference.
72 Luxury Lemans nicely optioned |
The Following User Says Thank You to indymanjoe For This Useful Post: | ||
You can get a set of tubular upper and lower control arms fairly inexpensive, seen and used ones from ebay that were under $300. It's hard to beat that for cost and peformance. And they come with bushings already in them.
Here's the type I used on the clone, $255 for the upper & lower set, free shipping: http://www.ebay.com/itm/64-72-Chevel...bd9a14&vxp=mtr You can offset the cost by selling your original control arms if you choose, probably get $100-$175 for yours. .
To bad I can't get tubulars for my 63 GP... :-(
1966 Impala SS |
They are a little heavier than stock, but that's the point, the stock flex like crazy, and crack. Especially with added side loads. .
Should I replace the centerlink between the tie rods. It doesnt come with a rebuild kit and wondering if those wear out. Thanks
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
No, because I believe stock is like zero caster or something, and very little or no camber, which is part of the point with the aftermarket control arms. Think I did like +2 to +2.5 caster, and like -.5 camber.
I did an f-spindle swap, and switched to uppers that are made for the swap. Think I'm in the 3.5 to 4 range on caster now. I sold the uppers to another guy, he's using them, and sure he would have mentioned if they didn't work for him. Ventura455 - Was the car you were using these on the Ventura or another A-body? .
Hm, that's possible...
Yeah, control arms for X bodies and A bodies are different, not sure why they list the same part number for those applications. On the one ebay auction I noted comments that the control arms aren't the same.
I so dig the action shot! Sweet! .
Ok, finally got the lower control arm and spring out of one side. Whewwww. Took a look at the upper i hope its easier. Not sure weather to take out the side bolts or the bolts with the spacers in them. I guess i will try both
The two bolts with the spacers are what attaches the control arm to the chassis. Those are what you take off in order to remove your control arm.
1966 Impala SS |
The Following User Says Thank You to redhook98 For This Useful Post: | ||
Houston i have a problem
So i took off the nuts with the shims in and there is not enough clearance to slide the arm off of the bolts because the arm hits the headers. It looks like the bolts are welded in is this normal? what now.
They're not welded they are splined interference fit. Tap them in with a hammer. Dont put a socket on the heads and spin them you will screw up the splines on the bolts. Ask me how I know.
New ones here if you need: http://www.ebay.com/itm/64-74-Upper-...2f3ed9&vxp=mtr |
The Following User Says Thank You to abefromen For This Useful Post: | ||
They are a splined/interference fit from the factory. You will need to tap them out if they are as installed by the factory.
If a prior owner turned them and enlarged the holes, they may have welded the replacements in so that they would not turn when installing the nuts. If they were welded in, removing them may be difficult so pulling the headers may be the better option. |
