| 1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out. |
Hi Guys
We Have a air cleaner issue on a new motor we have no clearance so can you post your different air cleaner set ups so we can get an idea on what we can do or what it will look like . Currently running a low aircleaner with twin outlets wrapped around the motor looking for room and cold air . Craig |
I almost bought a late 80s Firebird convertible with a carbed 305, supposedly it was a police or HD package, anyways, the air cleaner looked like regular black carb air cleaner with a single heat riser it looked like this
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
QF 750 VAC 2 on a EB manifold ( air gap ) but the vac port at the back needed to get clearance so owe installed a 1/2 ' spacer . And then the issues start
maybe you can plug that back vac port and install a T-fitting in another vac port so you can then manifold it out?
