1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
The only thing I can think of would be a hydraulic slave cylinder. But, I really don't know.
If you mean the two bolt holes to the left of the clutch fork, those are for the 65-70 full size cars. The z-bar pivot bracket attaches there (rather than using the ball stud screwed into the block that A and F bodies use).
Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
| The Following User Says Thank You to importsmasher For This Useful Post: | ||
Alright, then I know I'm not missing anything. Thanks. I will make some plugs then to plug the holes.
