Old 01-21-2014, 08:46 PM
mike76 mike76 is offline
Default Solid or hydraulic roller?
Which is best for a mostly street driven( some strip time) T/A for max power ,torque and drivability ? Combo is:
462" w/ Edelbrock 340 cfm heads
Beefed up TH 400, 1 7/8" headers w/full 3" exhausts
Assume each cam has the same duration( 250*ish intake and 650" valve lift)
Looking to make 660-670 hp @ flywheel .
All other components are the same to support this power level. Only difference is in the cam .
Thanks for your thoughts! Mike
Old 01-21-2014, 08:50 PM
tom s tom s is offline
Mostly street driven and drivability in the same breath as 670 flywheel HP?Glad it will be yours.Tom
Old 01-21-2014, 08:52 PM
grandville455's Avatar
grandville455 grandville455 is offline
Go with Hyd with solid lifters
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Lee's Avatar
Lee Lee is offline
For what your goals are, solid roller.
You need a decent amount of rpm to make that power. To control the valvetrain (Pontiacs are not the lightest) you will need a decent amount of spring pressure. A solid will allow you to use all the spring pressure you need.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 01-21-2014, 08:55 PM
BigB's Avatar
BigB BigB is offline
I am currently running a similar combo with a hydraulic roller cam with solid roller lifters. I want to do more driving, say 150-200 miles as opposed to my normal 30 at most. I will be changing over to hydraulic rollers and changing my springs. The solid roller lifters with high lift cam in my combo is going kill my springs one day. So my vote would be to go hydraulic from the start and save yourself some money.
Old 01-21-2014, 09:10 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Makes perfect sence to me ^^^^. You're gonna have to wind it up for all that.
I still have trouble discounting the horrors of loosing solid lifter needle bearings on the street after a couple thosand miles. However, the hybrid, tight lash setups don't seem to suffer from that problem.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 01-21-2014, 09:21 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Similar objective of 70 GTO project. All components needs to complement each.Premium SFI flywheel, torq converter, 1350 joints, drive line.NO STOCK components. Rears are debatable with the A body crowd. I prefer 9" at a certain level. Good luck
Old 01-21-2014, 10:19 PM
PONTIAC DUDE's Avatar
Thumbs up
Hyd roller lifters with Beehive springs and titanium retainers. Uses less spring pressure and still maintain lots of street time. Less load, wear and tear.
Old 01-21-2014, 10:52 PM
66bonne's Avatar
66bonne 66bonne is offline
This is the set up that P-Dude put on my KREs and his custom grind hyd roller [262/266, .621 valve lift w/1.65 rockers, 4/7 swap]. Pump gas and street driven.
Mid 10s on motor and high 9s with a little juice pushing 'two tons of fun' down the track.
Give him a call.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 01-21-2014, 11:33 PM
Lee's Avatar
Lee Lee is offline
I know where Warren Ksiez's old SR 455 T/A is now living. It has been running on the street since the late 90's with the same solid roller lifters, and has never lost a needle bearing.
My 7 liter SBF has been running the same EndureX roller lifters for over 5 years and many thousands of miles, no problem with those either (knock on wood!). My lash is .021/.024.
Old 01-22-2014, 12:14 AM
Thought that I would get more power w/a hyd. roller set up of the same lift and duration. Using the rule of thumb of needing about 10-12 more deg. of duration in a solid to equal a hydraulic.
How much are the EndureX solid rollers? Thanks, Mike
Old 01-22-2014, 08:28 AM
Tim Corcoran's Avatar
Hope I am not Hijacking here but do the OEM hydraulic rollers have pin oiling?
Tim Corcoran
Old 01-22-2014, 11:54 AM
Isky EZ roll$ on the "roadpaver" would be killer on the $treet!! (Some day, sigh...)
Old 01-22-2014, 12:36 PM
Steve C. Steve C. is offline
I suspect to make 660-670 hp @ flywheel with 250*ish intake and 650" valve lift using a hydraulic roller cam is going to be a stretch.
For interest evaulate Jim's 3950 lb race weight in relation to his ET an/or MPH get an idea of the horspower involved. His with 495 cid, 310cfm heads, Dominator carb on Victor intake. Note his hyd roller with 262/266 duration, 0.621 valve lift w/1.65 rockers.
On a old 462cid combo with 310+ cfm Edelbrock heads and a 254 degree Comp XE solid roller I made 600 hp at 6000 rpm with a Victor intake and HP950 carb. It should of been better but it had a lousy 9.7 compression ratio. My current 4.250" stroke 505cid with the same induction made 660 hp at 5900 rpm with only 10:1 compression, it currently has a 257 degree Ultradyne solid roller with about 0.689" net valve lift. If I were to make a change to a hydraulic roller for a similar power level I believe I'd have to add some additional duration.
Old information here:
Old 01-22-2014, 12:48 PM
He does have 340 cfm heads tho so he may require less cam, I think its doable or close to it...
Darby
Old 01-22-2014, 12:51 PM
Did I miss what CR and which intake and carb?Tom
Old 01-22-2014, 01:02 PM
I'll stick my neck out and suggest the infamous "Roadpaver" hydraulic roller ( Comp lobe 3115B) with 246 degrees intake duration and .4000" lobe lift in conjunction with solid roller lifters won't do it, not 660-670 horsepower.
ET/MPH = HP http://www.wallaceracing.com/et-hp-mph.php
Anybody out there with actual dyno numbers ?
Old 01-22-2014, 01:22 PM
Less cfm airflow involved but here are power numbers from a actual engine dyno sheet....
4.250" stroke, 4.180" bore, 305 cfm alum d-port heads, Torker II intake and 950 carb and the 246/252 "Roadpaver" hydraulic roller cam using solid roller lifters with a 1.52 rocker ratio. It made 589.7 hp at 5800 rpm. A long way to go to make 660+ hp.
Old 01-22-2014, 01:27 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Wow! That cam was done at 5800rpms?
Karl
Old 01-22-2014, 01:33 PM
OKay. This is through SD perf. D.B. is supplying everything. for that projected power level. 340 cfm heads, 10.5 cr., specially tooled intake ,etc. I don't have much doubt that through his recommendations I will arrive @ this power level. Again... the original question... Why would one run solids on a hydraulic roller if a set of hyd. lifters will give me more vs the solids(10-12*). I've read here that is the "rule of thumb". What am I missing? Am thinking that the hyd. lifters will give me enough rpm w/o the ultra stiff springs needed for the solid stuff.
