Old 01-27-2014, 11:03 PM
Blackened Blackened is offline
Default Trans leaks at speedo cable outlet.
A friend of mine has a 68 Tempest with its original drive train . He discovered that the transmission is leaking from the driver's side where the speedo cable exits the body of the trans.
Is there a common and easy fix for this?
TIA
Old 01-27-2014, 11:11 PM
jmt455's Avatar
jmt455 jmt455 is offline
Replacing the O rings should do it.
Inner ring seals around the shaft of the driven gear.
Outer ring seals the housing to the case.
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1924 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1941 Packard 120 coupe - Factory AC and OD.
1968 GTO, 428, THM400, 2.73 posi cruiser
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
The Following User Says Thank You to jmt455 For This Useful Post:
Old 01-28-2014, 01:56 AM
Thumbs up
Thanks for the quick response.
Old 01-28-2014, 08:28 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
If it has the original soft metal housing, seals won't fix it. The center hole gets
wallowed out and it leaks. I f it does have the old unit replace it with a hard steel one like
in the picture on the previous post along with new seals.
The Following User Says Thank You to gtohurstjudge For This Useful Post:
Old 01-29-2014, 01:56 AM
OK thanks! I'll let him know.
