Old 02-08-2014, 10:15 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Default Vibratory cleaner
I just got a vibratory cleaner to reclaim some old hardware - uses the green pyramids as media. After a few loads of hardware it seems to be leaving a sticky film on the parts.
Should this media be cleaned somehow?
68 GTO ragtop
91 T/A
69 XKE
Old 02-08-2014, 11:04 PM
marxjunk marxjunk is offline
yes.what are you using for solution? and what are you tumbling...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 02-09-2014, 01:16 PM
Birdguy's Avatar
Birdguy Birdguy is offline
In a former life working at a machine shop, we put hot water and Dawn in the vibratory deburr tubs and changed out with every load. The Dawn not only degreases the parts but helps prolong the life of the media as well.
Old 02-09-2014, 02:21 PM
fyrebird68's Avatar
Question
Its a dry tumbler. Using green "pyramid" beads. I think they contain some sort of resin.
http://t.harborfreight.com/5-lbs-rus...obile_redirect
68 GTO ragtop
91 T/A
69 XKE
Old 02-09-2014, 03:28 PM
fyrebird68's Avatar
Cleaning up rusty (not greasy) bolts and nuts.
68 GTO ragtop
91 T/A
69 XKE
Old 02-09-2014, 05:35 PM
i use one all the time..same type...same pyramids..you have to use some kind of solution if you want it to last...its lubrication..i use enuogh that it starts to make bubbles on the edges
For rust, just simple white vinegar..when ya pull it out wipe it off immediately and it will not rust for some time
dirt, i use dawn and water
wickedly covered stuff..CLR..its amazing
after 3 or 4 times, i wash it all with water and a little dawn..
Mark..
The Goat whisperer
The Following User Says Thank You to marxjunk For This Useful Post:
Old 02-09-2014, 10:32 PM
fyrebird68's Avatar
Thats what i was looking for - thanks
Bob t
68 GTO ragtop
91 T/A
69 XKE
Old 02-09-2014, 10:47 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I read the HF tumbler will shake itself apart eventually and you need to take it apart and use a little Loc-Tite in the fasteners.
http://www.pontiacpower.org/
Old 02-10-2014, 05:28 PM
fyrebird68's Avatar
Hah! Thanks.
68 GTO ragtop
91 T/A
69 XKE
Old 02-10-2014, 10:16 PM
Birdguy's Avatar
When it comes to rusty parts, I prefer to either hit them with the sand blaster or use this stuff. It is amazing.
http://www.oreillyauto.com/site/c/de...d=rust+remover
Old 02-10-2014, 11:30 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
They also sell evaporust at Harbor Freight. I think it is a little cheeper there. That is if you have a Harbor Freight close by.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
