Old 02-12-2014, 07:21 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default New axle seals and bearings
Where do you guys order new axle seals and bearings for your pontiac 8.2 rear ends? I'm having a difficult finding the correct parts.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 02-12-2014, 07:31 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default parts
Have had good luck with NAPA
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 02-12-2014, 08:02 PM
Ventura455 Ventura455 is offline
Try Randys Ring and Pinion. The have everything.
Old 02-12-2014, 09:16 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Napa lists BRG RW507CR but this is not going to look like the oe bearings because it's a sealed assembly that comes with a locking retaining ring. This was listed for a 67 GTO but i've used this style bearing for my 66 Tempests I had and didn't have any problems with it.
http://www.napaonline.com/Catalog/Ca...7CR_0172574050
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 02-12-2014, 09:21 PM
67gtospud's Avatar
With that part number I see one bearing with a locking ring, and one without. Do I need the locking ring?
Old 02-12-2014, 09:22 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Contact MONZAZ on the forums here. He has it all at a good price. He hooked me up with everything for my 70 Olds rear and the 64 Buick rear in the 65 I'm doing now. Very helpful.
67gtospud's Avatar
These are the ones im looking at:
http://shop.advanceautoparts.com/web...chTerm=bearing
Old 02-12-2014, 09:27 PM
67gtospud's Avatar
Originally Posted by 67gtospud View Post
And are these the seals I need?
http://shop.advanceautoparts.com/web...7-p#fragment-2
Yes I would get the one with the locking ring, it's a one time use.
6.27@107
9.97@131
Old 02-12-2014, 09:37 PM
If that's the seal they call for than it's for the original style set up. Someone correct me if i'm wrong but you don't need an extra axle seal with the sealed bearings. I never put one on mine and no leaks.
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 02-12-2014, 09:40 PM
67gtospud's Avatar
Alright, I'm going to order new bearings and flange gaskets. I see that it's listed that 4 are needed per car, I thought it was only 2?
Old 02-12-2014, 11:13 PM
RW507CR is the correct sealed axle bearing. The R in RW507CR is for the retainer. The axle seals are inboard, up in the axle tubes & you will need two National 8594S's.
Make 100% sure there is no wear in the axle mating area. It should be the same thickness where the lock collar & axle bearing are pressed on. If there is any evidence of the sealed bearing seizing & chewing of the axle, the axle should be replaced.
Old 02-12-2014, 11:32 PM
67gtospud's Avatar
I had the differential apart when I put all new bearings inside but for the life of me I don't know why I didn't replace the axle bearings, seals or flange gaskets. The axles were in excellent shape.
So now I guess my question is: do I need the national bearings and seals or will just the sealed bearings and new flange gaskets do?
Old 02-13-2014, 12:12 AM
National will be the seals, that is Federal Mouls line of seals. Bearings, most likely will be Timken, Federal Mogul (Bower-BCA). Don't accept Chinese bearings like the Partsmaster line.
On the seal, I'd replace the seals, they're most likely 45 years old. What seems to make them go bad is when a sealed axle bearing seizes & chews up the axle, the axle then has more movement up & down,side to side & the old axle seal is opened up slightly. With the sealed axle bearings being permanently lubricated internally, there is not supposed to be rearend grease out on them. The axle seal stops the grease from reaching out there. Later, tapered axle bearings require the lubrication of the axle grease & as a result have an external seal.
Old 02-13-2014, 12:13 AM
Peje Peje is offline
The gasket between the backing plate and axle are made of metal original.Then you have a paper gasket on the brake side.
Always replace the oil sealing ring in the axle when replacing bearings,very low cost.
And use Loctite 641 on the outer bearing ring to prevent spinning in the axlehouse.
DO NOT use Loctite 638,it`s VERY strong and you are gonna need inductive heat to get it loose.
Like `ol Pinion head said: Make sure that the shaft is in good condition.One of mine was welded under the bearing and it snapped.Very nasty experience!!
Old 02-13-2014, 12:14 AM
54nomore's Avatar
54nomore 54nomore is offline
Yes, you still need the seals. They keep the gear lube away from the back of the bearing where otherwise it may find its way past the bearing and into your brake drums.
