Old 02-25-2014, 08:01 AM
tstevea's Avatar
tstevea tstevea is offline
Question Howards retro fit 4 7 swap HR cams
Anyone run hr howards cams they have decent selection...
Old 02-25-2014, 08:54 AM
Jurassicgto's Avatar
Jurassicgto Jurassicgto is offline
Thanks for shining a light on these. Saw one I'd like to try. Less lsa than sd performance ones leads to peakier hp/torque curves and rougher idle but the 4/7 swap is supposed to help smooth out idle and crank stress along with making more power. Nice to have options and easy click buy now on the Summit web site.
Old 02-25-2014, 08:57 AM
Torquewar's Avatar
Torquewar Torquewar is offline
I would also like to hear about any combos/comments out there with these camshafts.
Old 02-27-2014, 02:01 PM
WARPed's Avatar
WARPed WARPed is offline
If you are running a dual plane intake do NOT use a 4/7 swap cam. A total waste of money and may actually hurt your performance by doing exactly the opposite of what it was supposed to do for a single plane manifold..
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 03-01-2014, 05:28 AM
jonathonar89 jonathonar89 is offline
Can explain more on this?
What about new gm ls firing order?
I have a Performer RPM and I'm interested in running the latest firing order as opposed to just a 4/7 swap.
Old 03-01-2014, 11:40 AM
Lee's Avatar
Lee Lee is offline
I recently designed a HR for a low compression (8.3:1) 400. R/A manifolds, regular Performer intake, Q-jet, 4spd tranny. It was a 4/7 swap, small duration and rather large LSA.
It put 314hp to the wheels, and a broad power band.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
