Old 03-22-2014, 01:05 PM
JLHarper's Avatar
JLHarper JLHarper is offline
Question BUILD SHEET RECOVERY?
Anyone had success cleaning one up like this example?
It was between floor metal and the original under carpet heat/ noise padding, may have gotten wet too.
Not as thin as it looks, just in the missing areas. Can "almost" see the build details, but needs some help.
Someone told me some years ago they "might" come back if soaked in a isopropyl / water solution...(?)
Thanks....
Old 03-22-2014, 02:11 PM
The Boss's Avatar
The Boss The Boss is offline
I believe soaking it in acetone will work. Try it on one of the bottom pieces first.
And go racin' in the street.
Old 03-22-2014, 02:33 PM
marxjunk marxjunk is offline
starter fluid for the bbq pit..its what they use to wash checks too...test it first..it can be agressive
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 03-22-2014, 03:21 PM
Held for Ransom's Avatar
Paint thinner and a cookie sheet or throw away aluminum baking pan. Just enough to cover it. Lightly swirl the mixture by shaking the pan. Change out the fluid when too dirty.
Old 03-22-2014, 03:23 PM
Does it say Wilkesboro NC dealer ?
Some years back a guy on here had one just about same degree of total dark from floorboard. He used a baking pan of similar size parameter and let it soak in about 1/2" of lacquer thinner for extended periods.
believe he used a facial make-up brush to give it some help along the way while soaking. After 2 or 3 rinse/repeat cycles he had a fully legible Bsheet.
acetone and bbq fluid sound good too - bbq fluid might be the most lingering aroma though. same problem with gas and diesel fuels - fwiw
if you can still access the area where the sheet was found - test various solvents and see what removes the tar stains from floor the easiest and gentless.
You could probably pull most the info in a dark room holding a light source behind it.
Possibly capture it with a camera ... or have a dictation assistant manually transcribe the data as you call it out. pita
Old 03-22-2014, 06:23 PM
A Schab A Schab is offline
I had one that was unreadable from a 69 Z/28 that cleaned up very good with brake cleaner.
Old 03-22-2014, 06:49 PM
steve v's Avatar
steve v steve v is offline
x2 on the lacquer thinner in a cookie sheet method. My TA's build sheet was as black as yours & after 4-5 five changes of the thinner it came out legible.
Old 03-22-2014, 07:18 PM
hobi hobi is offline
Default BUILDSHEET
Thanks....
Hey Jeff looks like you might have to call FORENSIC FILES good luck like to know how you make out.
Old 03-22-2014, 10:04 PM
JLHarper's Avatar
Thumbs up
Thanks for the tips everyone!.....
I used Mineral Spirits in a cookie sheet for six minutes then soaked/rinsed twice more changing water twice.
Pressed in paper towels drying flat. I can read it now. Top missing chunk I have in a file at my office, and will clean that piece later.
BVZ: car is from Lebanon, MO
Old 03-23-2014, 07:36 AM
The Boss's Avatar
I can see 455 & hood Ram Air - whatcha got there Jeff?
Old 03-23-2014, 10:29 AM
RAIVJUDGE's Avatar
RAIVJUDGE RAIVJUDGE is offline
Use prep solvent in a cookie tray and let it soak over night, The tar will lift out of the paper and not harm the buildsheet. My old black 71 Judge's build sheet looked just like yours and lightened up and your could read everything.
I would stay away from anything stronger then prep solvent.
Atoll Blue, Blue interior, 1970 RAIV Judge/4 spd/ 3.90/ pwr steering/ pwr brakes/ hoodtach/ gauges/ sport wheel/ console/ remote mirror/tinted glass.
Starlight Black, Camel Tan interior, 1978 Trans Am . Auto/AC/door edge guards/ am/fm, Cassette stereo/ floor mats frt and rear/Hurst Hatches
Cameo White, Blue interior, 1971 Trans Am/4spd/ Am/Fm/ power windows / AC. 28,000 original miles
Old 03-23-2014, 10:32 AM
RAIVJUDGE's Avatar
Haha premature posting. That's what happens when you don't read to the bottom first LOL. Glad it worked out for you.
Old 03-23-2014, 02:16 PM
JLHarper's Avatar
Thanks RIVJUDGE....!
THE BOSS: this is the Palisade Green 455 w/ RA 70 driver GTO Steve V went through last year.
The document looks much clearer now since its dried.
EDIT: may start different thread on other questions.....
Old 03-23-2014, 06:26 PM
Glad you got good results with that Harper.
Could you post a nice clear shot for the archives ?
And what is the body build date
YA block early car
Looks like you got your radiator code too
Old 03-23-2014, 07:17 PM
The Boss's Avatar
Ahhh, yes, now I remember!
Nice!!!
Old 03-24-2014, 11:12 AM
2002Z4CSS's Avatar
So how is the finished build sheet look?I
1971 Pontiac GT-37
Old 03-24-2014, 01:22 PM
Icefan71 Icefan71 is offline
Thats amazing. I wonder how many build sheets were thrown away because they looked like the before pic.
1972 Pontiac Lemans 350 Qjet Summit 2800
