Old 04-26-2014, 06:06 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Default what engine do I have
Hey guys. I need a little help with this one. If I remember correctly it was pulled out of a 74-76 Bonneville and was suppose to be a 455. When I got there I saw it stamped with 400 so hard telling what it really is. I bought it about 12 years ago and just never did anything with it. I still don't have the money to build it but I am going to get it cleaned up and inspected to see if it's worth saving any longer.
I tried to find the info about this block but I'm still not sure what I have.
ID:	361520   Click image for larger version
ID:	361521   Click image for larger version
ID:	361522   Click image for larger version
Old 04-26-2014, 06:11 PM
jwcfbd's Avatar
It's a 2 bolt main and there is a C in front of the 151201 stamp.
Old 04-26-2014, 06:13 PM
goatless's Avatar
goatless goatless is offline
1971 2bbl 400.
1966 GTO
Old 04-26-2014, 06:38 PM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by goatless View Post
1971 2bbl 400.
X2.
Old 04-26-2014, 07:18 PM
jwcfbd's Avatar
Thanks guys.
So then would that make the date code I281 Oct 28 1971?
Old 04-26-2014, 07:21 PM
gtofreek's Avatar
gtofreek gtofreek is offline
It would be September, 28'th, 1971, making it for a 72 production year car. So, technically, it's a 72 400.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-26-2014, 07:34 PM
goatless's Avatar
This- I had a brain fart and only looked at the "1". Basically the same motor from '71 to '72. Different head casting number but same low compression 2 bbl set up.
Anyhow the block is still good as a 400 core to build as a 400... or a stroker.
1966 GTO
Old 04-26-2014, 07:59 PM
jwcfbd's Avatar
You would think after 43 years of birthdays in September I would know it's the 9th month and not Oct. Lol
Thanks again guys
Old 04-26-2014, 08:04 PM
jwcfbd's Avatar
This- I had a brain fart and only rotating the "1". Basically the same motor from '71 to '72. Different head casting number but same low compression 2 bbl set up.
Good to hear. My plans are to get it to a 455 with a full rotateing assembly from Butler.
Old 04-28-2014, 12:11 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Looks to be the same block as im using. Mine came out of a '72 catalina
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 04-28-2014, 12:58 PM
72blackbird 72blackbird is offline
To me the most important numbers are the 6-digit engine block ID no., cast in raised numbers. "481988" means it's a good 400 block- end of story.
Geno
Old 04-28-2014, 04:00 PM
jwcfbd's Avatar
Geno
Great thank you for that.
