Old 04-30-2014, 04:50 PM
Darth Menace Darth Menace is offline
Default assistance in putting some body pieces back on
I am currently in the process of putting some stuff back together and i was wondering if i could get some assistance. I will mention them all here as they come instead of starting a new thread for each one.
First off is the rear bumper. I pulled the old one off to sell it and now i have the 3 brackets there ready to go on since the new spoiler is coming in a few days. I took a look but i dont know for sure how they bolt on and last thing i want to do is do it wrong and completely have to redo everything.
Next is the mirror. I put it back on with that metal piece then the plastic cover overtop. Now the mirror just flops back and there. Good one there I know.
Old 05-01-2014, 08:46 AM
Give us a bit more info, year, model and bodystyle etc
Old 05-01-2014, 09:01 AM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Darth, on the rear view mirror on the door, the plastic gasket goes on underneath
the metal bracket, not on top! On the rear bumper brackets, the two big brackets
bolt on to the bumper with the protruding edges facing towards the outside of the car. the
middle bracket is impossible to put on wrong......it can only be bolted on one way.
Old 05-01-2014, 10:40 AM
it is a 69 Custom S convertible, but the bumper in question is a 69 gto bumper
Old 05-01-2014, 10:46 AM
I might have described something wrong. The metal piece for the rear-view mirror has the little section for the ball of the mirror to slide into, then it bolts to the car. From there the plastic piece I am talking about is the actual exterior piece that you see when you look at it.
As far as the bumper brackets. Which bracket goes on which side (they are mirror to each other) and which side of the car do they attach to? The reason I ask this is that there look to be 3 ridges for the bracket bolts to go through, but they dont seem to line up no matter what I tried. Wish I didn't take these off when I took the bumper off. I assume I put these on and then the bumper afterward, and not attach these to the bumper while the bumper is off the car...correct? Sorry for the dumb questions
Old 05-01-2014, 06:31 PM
The bumper brackets are not identical.....they are only flat on one side.....the
other side has 90 degree ribs on the edges to strengthen them. You should bolt them to
the bumper then install the whole unit on the car. In the future, just unbolt the chrome
bar from the bumper brackets to remove the bumper and leave the brackets on the car...
that is much easier. The flat side of the brackets should face up to the outside of the frame rails. I don't understand what you are talking about on the mirror. There are only three parts,
the mirror assy, the metal bracket and the plastic gasket under the metal bracket that faces
up to the door skin.
Old 05-01-2014, 06:46 PM
Ya, I got a bit gung-ho with the bumper. Kind of crappy I took too much apart, but that's not the first time I've done that.
I will have to take a picture of the mirror. Oddly all pieces are together yet it just wobbles around.
Old 05-02-2014, 08:41 AM
One more thing Darth.....when you tighten the nuts on the bumper bolts
that go through the chrome bumper bar, DO NOT make them very tight! You want just a little
past finger tight on those or you will flex the bumper bar and crack the chrome!
Old 05-02-2014, 04:14 PM
Thanks man...I sure would have overtightened them. You saved me some cracked chrome on my new bumper. I went to a fastener store today in hopes to get some new bumper bolts, but it didnt happen
I love getting these things put back together and looking good. For a while it looked like the car had puked all it's parts over my garage.
Old 03-06-2015, 10:16 PM
Also, I was trying to put my rear view mirror back up, but it doesn't seem to want to stay. The metal part is secure holding the mirror in, but the back clips on the plastic part keep popping off and the mirror goes all wobbly. I find it hard to believe that the plastic lip is all that holds the mirror on place once it slips into the two prongs on the back of the metal piece. Or am I missing a piece (or just being braindead). I really need to start taking some pictures before I take something apart
Old 03-06-2015, 11:22 PM
I read this whole thread and I was wondering when you guys were going to realize that you might be talking about two different mirrors.
Old 03-06-2015, 11:27 PM
This is a rear view mirror though....what am I missing here?
EDIT: Now I see. GTOHurstJudge was talking about the side mirror. My bad
Old 03-06-2015, 11:56 PM
PontGuy's Avatar
PontGuy PontGuy is offline
Darth I've been taking a break since the front end suspension work and just watching along as others help out. But I'll take a shot at this one since something jumped out looking at your picture. The screw that holds the rear of the metal bracket to the frame is supposed to go through the plastic trim piece before it goes through the metal bracket. That way the plastic piece can't just pop off and everything should stay secure.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 03-07-2015, 12:58 AM
Ouch, I will have to wait until I am home from work (most of my forum typing is done at work). I am sure it will be okay and my tail will be between my legs once again.
Old 03-07-2015, 02:58 AM
turn out that I was wrong...shocker.
It turns out it wasn't the plastic piece had to go through that screw hole on the metal piece as the holes don't line up, but what I was missing is the two little prongs on the front of the metal bracket that clip into the windshield frame.
It is funny that I can take this thing on and off numerous times and not notice that until I post here and then problem solved. I love cars with a passion, but this proves I am stupid with them.
Oh well, what can I say, I only have 1 more thing on my to-do list now. Whoever would have thought I would be saying that one day!
Thanks again
Old 03-07-2015, 07:53 AM
PontGuy's Avatar
Glad to hear another problem solved.
I admit that I was just "giving it a shot" in this case. I haven't had my mirror off since I mounted it five years ago
Old 03-07-2015, 12:24 PM
Another problem solved is saying the least. I have stared at this thing for ages while it annoyed me but I never put much effort into it because I had so many other things to do on the car. Glad to get that dumb mirror out of the way!
Thanks again
