Old 06-14-2014, 06:02 PM
71lemans71 71lemans71 is offline
Default Spider cracks?
I have a ton of spider cracks all over my front bumper any way I can fix it
Sent from my iPad using Tapatalk
Old 01-19-2015, 08:18 AM
niceta's Avatar
niceta niceta is offline
There is some good posts on here about how to restore a front endura rubber bumpers. From what I have read you need to V-grind out all the cracks and use a 2 part flexable filler to fill and finish the bumper with. I am using Dominian sure seal flexable bumper repair which is a 2 part epoxy filler that sands very nicely. Then from what I have read you should not use filler or polyester type primer. You should use epoxy primer. This is my first attempt but here are some pics of what I have done so far. The Dominian sure seal stuff is flexable. I have tried to push on the bumper after a couple coats and it has not cracked if that means anything. I am going to let it sit for awile to see if it stays flexable before priming.
ID:	387832   Click image for larger version
ID:	387833   Click image for larger version
ID:	387834   Click image for larger version
ID:	387835   Click image for larger version
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes.
https://www.facebook.com/media/set/?...7567172&type=3
Old 01-19-2015, 08:24 AM
niceta's Avatar
Here is a pic of the bumper before grinding out spider cracks. These cracks were the same when the paint was still on.
Old 01-19-2015, 08:25 AM
niceta's Avatar
forgot to upload. here ya go
Old 01-19-2015, 10:27 PM
Originally Posted by 71lemans71 View Post
I have a ton of spider cracks all over my front bumper any way I can fix it.
Have you removed the paint and primer yet? Just wondering as it's hard to tell what's cracked until you get all the coating off.
I used the 3m flexible bumper repair stuff. You can get it at Advance, etc.
As was said above, there are a LOT of posts here on refinishing endura bumpers.
