Old 09-23-2014, 10:58 AM
chaz069 chaz069 is offline
Default 73 455 Oil dipstick tube height coming out of block.
I replaced a rusted and missing oil dipstick tube coming out of the block with a stainless one. Does anyone know the exact height or length of the small tube that comes out of the block? Thanks chaz069
Old 09-23-2014, 11:25 AM
cnc's Avatar
cnc cnc is offline
I just installed mine and when u install the tube the inside end sits flush with the lip of the block webbing....or slightly below
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 09-25-2014, 08:59 AM
First, thanks for the info. my 455 had a rusted tube coming out of the block , and I used a stainless tube acquired from a local tubing company to replace it. Are all block tubes the same length? I have an A/C car with an extension tube and longer oil dipstick. When they duplicated the tube, we were not sure what the actual length was and guessed. Thanks chaz069
Old 09-25-2014, 12:59 PM
cnc's Avatar
cnc cnc is offline
Hmm that I dont know...maybe check the py parts catalogue and see if the lowers are different...
My car is no a/c and I'm running a windage tray as well....Chris
Old 09-25-2014, 04:10 PM
Lupdiesel Lupdiesel is offline
From one of my old pis.. looks like 7 3/4 to 8 inches. Sorry for the fuzzy pic. This is a 71 400 and BOP stainless tube
http://s903.photobucket.com/user/lup...tml?sort=6&o=0
Hope this helps
Kyle
Old 09-25-2014, 07:38 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
From what I remember. the internal dimentions of the LOWER tube depends on whether or not you have a windage tray. If you have a try, the try locates the lower tube. No tray, the lower tube bolts to a bearing cap via a bracket attached to the lower tube. Either way the lower tube looks the same OUTSIDE of the block. If you have air, there is an extention tube that fits into the lower tube, but the lower tube still looks the same outside of the block.
The lower tube installs from inside the block with the oil pan off, so I'm curious how you are fabbing a new lower tube. I'm assuming this is being done with the engine in car, and oil pan on?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 09-26-2014, 09:42 AM
PAUL K's Avatar
PAUL K PAUL K is offline
The length of the tube that presses in the block are all the same length from 1969 to 1979 and they might be the same pre-69. I'm not sure on that.
Go fast, see Elvis!
