Old 10-12-2014, 04:02 AM
gomickeygo gomickeygo is offline
Default 55 pontiac front disc conversion
Any one out there found a true bolt on
Old 10-12-2014, 09:03 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
The kit from Scarebird looks like a decent bracket kit. I had some 63 spindles on my car at one time and his kit fit well.
https://scarebird.com/index.php?rout...&product_id=78
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 10-25-2014, 08:46 PM
lnirenberg lnirenberg is offline
Used the scarebird on my 57 safari and it worked great with the recommended calipers and rotors.
Old 10-26-2014, 12:36 AM
blueghoast's Avatar
Did you use a proportioning valve or just use the stock distribution block?
GT.
Old 10-26-2014, 01:18 PM
At some point the stock line configuration is going to have to go from 1/4 to 3/16 line. All of the 1/4" line is gone on mine. There are adapters for this also, but I put in an adjustable proportioning valve on mine and set it in the middle and works good. But i'm also using a manual 1" bore mc mounted to the firewall , not the stock single master cylinder.
6.27@107
9.97@131
Old 10-27-2014, 02:35 PM
KoolKat57 KoolKat57 is offline
I have the kit from Scarebird, and all the related parts.
I have not installed mine yet on my '57 because of the stock MC.
Did you use a different MC and how did you mount it?
My '57 is a stick shift so I want to keep the MC on the frame.
Has anyone done that?
KK
Old 10-27-2014, 03:10 PM
KK , If you haven't seen this I was going to get this bracket and set it up on the frame before I mounted mine on the firewall. I figured with my headers something else in the way.
https://scarebird.com/index.php?rout...product_id=123
6.27@107
9.97@131
Old 10-27-2014, 05:56 PM
Thanks Bill, I will look into it!
KK
Old 10-27-2014, 08:24 PM
Thanks for the kudos.
KK - what size and type of rim are you planning on using?
Old 10-28-2014, 04:00 PM
Scarebird
I have 15"X6" American Torq Thrust II'http://
Old 10-29-2014, 01:11 AM
OUr base kit will work there no issues - looks good!
Old 10-29-2014, 12:02 PM
Teej's Avatar
Teej Teej is offline
I put a Scarebird conversion on my '58. Works great. I did replace the stock MC with a balance-bar and two separate manual MC from Wilwood. Not sure that setup is the way I'd go again, but all the stuff at the wheel was a piece of cake. Put another setup on my '66, but haven't had the chance to drive it yet. Still seemed to go on without too much trouble.
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
Old 02-19-2015, 05:27 PM
Default Brakes
Any one interested in putting front discs brake on their 55? I have brakets and spacer that will change front set up to disc brakes. Only problem is the front changes to 4.3/4. Easier to change style on rims. Pm if interested I have a few set
